Question about Simpson Washing Machines
My simpson encore 757 shows PU error code. What is this?
tech240
  • 169 Answers
SOURCE: I have a Simpson encore
the manufacturer should be able to tell you what the error code means, look them up in your manual and call them or send them email. even though all codes may not be listed in the operating instructions they supply to consumers they will tell you when asked.
Posted on Apr 22, 2008
SOURCE: simpson washing machine encore 756
our simpson encore 756 flashes SP can anyone tell us what it means and how do we fix it thanks mark
Posted on Jun 18, 2010
  • 713 Answers
SOURCE: simpson encore 605 wash machine 6kg. Washer pump
Hi mark just read your posting.Now what country do you live in.If you live in Australia then I can give you some phone numbers.Regarding your machine it does sound like the control board.Probably the power supply section of the board is faulting.Please reply with additional information and I can help you further.
Posted on Jun 19, 2010
Testimonial: "Nice reply with information to put me in contact with someone who may have parts. Thanks. I await some more contact phone numbers."
Daniel S
  • 4323 Answers
SOURCE: Simpson Encore 806 PU/PO display
Hi
The issue is with the control board that should be replaced as it is bad. You can unplug it and then blow air on the control before replacing if this wont solve the issue then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 08, 2011
  • 6277 Answers
SOURCE: i have ezi set simpson
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 08, 2011
Hi,i have a Simpson EZI Sensor 6 kg top load it has PU error code, any one knows what this code reflects? Thank you in advance Mike
It means pump error. Water is slow to drain or not draining at all. May be a blockage or could be a faulty pump.
Dec 06, 2016 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
Simpson encore 806 washing machine beeping and screen showing DF
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Jan 11, 2009 | Washing Machines
Simpson washing machine encore 756 displays error df and will not complete cycle
Aug 03, 2008 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Vernon Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
