Question about Fisher Paykel Fisher & Paykel DishDrawer DD24SI7 Semi-Integrated Single DishDrawer with 7 Place Settings, 9 Cycles, Eco Option, 163 Degree Sanitizing Temperature, Delay Start and Adjustable Racks: Requires Custom Panel/Handle
Can you please tell me how to reset the machine after the F^ code appears and I have fixed the flooding problem it is model DW60CE
  • 33 Answers
The dishwasher should reset when the power is turned back on. Make sure the water is turned on also. Sometimes pressing the keylock button and holding for 4 or 5 seconds will allow you to continue. What is the actual F code you are seeing?
Posted on May 09, 2015
How do I fix a Duet Front Loader displaying a F8 E1 error Code?
Without model Number going on experience they change based on model the error codes F8E1 is a long fill error code if you have flood safe water supply hoses install regular washing machine hoses most common issue pull machine out remove back panel inspect black hose that runs from pressure switch to plastic tub the clip that holds it in place usually comes loose allowing it to rub against the rotor of the motor causing a hole to develop which will give a F8E1 code
Aug 30, 2014 | Whirlpool Washing Machines
Can't get machine to start a cycle. When press the start/pause button, the door open light begins to flash. After a few seconds, it stops flashing and the start/pause button begins flashing. I have checked...
It is hard to tell if there is no model number. Normally, WP machine has error code appeared on the display. I guess your unit does not have display, so the combination flashing is a signal to tell you what wrong with the system. You can check the service manual normally taps inside the unit.
Oct 22, 2013 | Whirlpool Washing Machines
My machine has an f.08 error, please can you tell me how to fix this?
Can you tell me what the manual says about the code? It doesn't have to be word for word just the idea. Different machines have different codes. If you can open the door give me the full model number as well. Thanks.
Jan 12, 2013 | Washing Machines
DW60CE dishwasher - E6 fault flood switch activated. Unit has not been use
After tipping the dishwasher on its side & it releasing its water from its tray, the fault cleared. I removed the bottom cover & inspected its internals for traces of a leak or evidence of leaking.
I could follow the calcium or detergent trail from the rear water duct connection near the top feeding sprayer arm, down the back of the dishwasher & into the tray. The lock nut on the duct where it enters through the inside S/S skin had become loose & simply needed to be tightened.
Jun 09, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Anti-flooding system has activated.
Tip washing machine towards you, water in bottom of machine will pour out, so be ready! Should work after that, mine did!
Aug 23, 2009 | AEG Washing Machines
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
WASHING MACHINE
WHAT MAKE AND MODEL,THE EASYEST THING TO DO FIRST IS TRY UNPLUGGING IT FOR 2 MINUTES AND SEE IF IT RESETS ITSELF,LET ME KNOW-MIKE
Jun 13, 2008 | Washing Machines
Fisher Paykel Fisher & Paykel DishDrawer DD24SI7 Semi-Integrated Single DishDrawer with 7 Place Settings, 9 Cycles, Eco Option, 163 Degree Sanitizing Temperature, Delay Start and Adjustable Racks: Requires Custom Panel/Handle Logo
137 people viewed this question
Top Fisher Paykel Dishwashers Experts
Barry37
Level 1 Expert
Rocketmanusa
Level 1 Expert
Bill Boyd
Are you a Fisher Paykel Dishwasher Expert? Answer questions, earn points and help others
