Question about Husqvarna WE261 960220007 26 190CC Weed Eater Rear Engine Rider Mower
Battery was dead. Charged it up. Mower starts and runs rough, surging and bucking. However, When I started it and disconnected the battery, it immediately smoothed out, running perfectly.....super smooth? What could it be?
  • Kprime
    Kprime Mar 28, 2015
    That's curious, I'll have to think on that tonight
    Habit-Forming:
  • 187 Answers
One of the cells in the battery is probably not working, and the charge is leaking off.
That may be why you had to charge it.
A new battery should solve both problems.
Posted on Mar 28, 2015
    Sergeant:
    Champion:
  • 242 Answers
Sounds like you have a short or have put a cable in the wrong spot
disconnect and try again
Went to start 2007 Santa Fe, and battery was dead. Jumped it; it ran, but all of a sudden running rough, no gas pedal functionality. Limp mode I suppose. Pulled codes 2106 1295 and 2135.
You have to do a throttle relearn procedure after disconnecting the battery. You'll also have to drive it a while so it can relearn its Keep Alive memory.
Feb 26, 2018 | Cars & Trucks
Engine surging at idle 2001 tt quattro
I strongly suggest you hope the alternator is a dud because disconnecting the battery while the engine is running can cause a voltage surge capable of frying electronics...
Feb 11, 2018 | Cars & Trucks
Battery will not hold a charge. i charge it or jump it off and it will be dead the next time I use it. I even bought a new batter and it was drained when I went to use it again
It sounds like it has a short on it or the alternator isn't giving a charge. check the wiring for breaks... charge the battery up and get a altmeter to test if when running the battery is getting a charge, hope this helps
Mar 30, 2015 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
I have a 1997 BMW 528i that idles rough and now the check engine light came on. It idles rough, but when you press on the gas it runs smoothly. What could be the problem(s)? And the battery goes dead
Cars use the battery when they are not running. It is called parasitic drain. When the light comes on if you take it to a major autoparts stor like checker, advance or autozone, they can check it for free and tell you what the light means.
Feb 15, 2014 | BMW Cars & Trucks
Battery will not stay charged.
Will the battery stay charged with one terminal disconnected?
if yes the you have a wiring problem. If no get a new battery.
What is the battery voltage when mover is running?
12.6v = not charging while running
13.7v = good charging
Oct 23, 2013 | Garden
Engine wont start, BCM just replaced, inflatable restraint and check engine light on.
need to start with do you have any obd code with key turned on
caddy is more complex system than most , check fully charged battery, and not a jump start, and battery is in very good condition .disconnecting battery would only clear codes leaving you with nothing to go on hopes this is some help to you.
Sep 29, 2012 | 1991 Cadillac DeVille
Mower runs great, problem is battery goes dead, its a new battery, i recharged it, measured the voltage at 13.41, started it, it measured 14.47 volts then drops a few decimals every minute like 14.42 after...
Try disconnecting the battery and note if the voltage drops.
If it does, the battery is not holding a charge.
If it keeps its voltage, the problem lies in a minor short in the mower.
You have to determine which item has the problem first.
Is this helpful?
Gary
Feb 28, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Mower will run if jump started and continue to run but when turned off and back on will not start until jumped again.Meter does not show mower is charging
The battery needs to be checked.If its running with jump start this indicates that mower is fine but the battery is not supporting it for normal start.In some cases the battery has low charge so getting the battery charged helps.In some cases the battery is dead so battery needs to be replaced.And in some cases the battery is new ,its charged but actually the terminals from the battery gets rusted and do not get connected so this leads the problem.So check the battery,if its low on charge get it charged,if its not getting charged then replace the battery ,if its charged and new then clean its terminals and reconnect and check. But if battery is properly charged and connected properly ,then also you see the same problem then its fault in the starter and starter solenoid.It needs to be checked and replaced.
Thanks. Keep updated for any more query.you can rate this solution and show your appreciation.
Jun 26, 2010 | Garden
Husqvarna WE261 960220007 26 190CC Weed Eater Rear Engine Rider Mower Logo
162 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
