Question about Brother SE400 Computerized Embroidery and Sewing Machine
My thread cutter button is not working. The blade is moving i can hear it when it does, but for some reason its not catching and cutting the thread. I have had my machine right at one month. Purchased it new from overstock.com
    Master:
  • Brother Master
  • 470 Answers
There may be something in the Manual about it. Otherwise, Maintenance/Repair at a local store.
Posted on Mar 28, 2015
    Top Expert:
  • Brother Master
  • 42,546 Answers
Call for a service under warranty or take it to a sewing machine agent to have it fixed under warranty
Brother lb6770 The hook comes out and usually misses thread it is supposed to cut even when does catch blade fails to cut thread.Is this adjustment that's needed or replacing?
If the felt pad is missing from your bobbin case, it won't catch the thread properly and if it's not cutting even when it has caught. The cutter blade needs to be replaced.
Aug 30, 2016 | Brother Sewing Machines
Bobbin thread not cutting
With the bobbin case out of the machine, touch the cutter button. Do you see the cutter arm move from left to right and then back left. If not the cutter arm is out of place. If it does it is something else.
I usually check two things:
1 - your cutter blade might be missing or dull and needs to be replaced. I would not recommend doing this yourself unless you are very good.
2 - many times there is lint or loose threads around the cutter in the area to the left of the needle plate that needs to be cleaned out. You can remove the cover to this area by first removing the needle plate and bobbin case. Then the cover is accessible to pop off by sliding the tip of a small screw driver under the cover at the bottom right corner of the cover. There should be a little opening. Carefully pop the cover off but be careful that the blade mechanism does not come off too. With your finger carefully hold the silver metal blade area steady and pick out the loose threads/lint from around the copper looking metal part. There is velcrow on the tip of the copper metal part so be sure that you don't remove that too. That's what holds the thread for the blade to cut it. If velcrow is missing, or the silver metal part is out of place that could be the problem also.
I recommend that any repairs/service be done by an authorized Viking dealer. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck
May 13, 2014 | Husqvarna Designer I
Babylock espire thread cutter stopped working
Your cutting blade is dull. It needs to be replaced by a experienced technician.
Cheers,
K
Feb 27, 2014 | Baby Lock Espire
I have a Pfaff grand Quilter and my top thread is not catching the bobbin thread. When it does the stitches skips. Can anyone help!?
Hello
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Jul 15, 2011 | Sewing Machines
Overlocker not cutting and, rolling fabric and tangling thread. It began when I went over a seam. It began to roll the fabric under rather than cutting. It then stopped and tangled the thread. Tried...
look on yu tube for a video on doing a rolled hem, and you'll see how to move the blades. perhaps you have accidently just moved them and need to engage them properly; good luck
Sep 14, 2010 | Singer Sewing Machines
The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Feb 28, 2010 | Husqvarna Designer I
I am having trouble with the thread catching. I have tried combination's of the same thread & bobbin thread in the bobbin. I have changed to the needle. Under the plate I see a tension to the left. It...
if you are using HUS bobbins make sure you have it in the holder with the H facing up and then wind through the 2 small pieces of metal.. Hope this helps!
Jan 15, 2010 | Husqvarna Designer I
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
Brother SE400 Computerized Embroidery and Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
