Question about Stihl Garden
What are the torque specs for cylinder head
FS-55 1.66 cu. In engine
  • Stihl Master
  • 1,169 Answers
Screw IS-DG5x60 Muffler/cylinder 6.6 Ft-lbs 9.0 Nm
Posted on Mar 27, 2015
In setting up my new fit bit, it locks up on the question of setting up name, email and password
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Hi Terri
You will have to contact them LIVE using their online Chat support. They will verify your authentication then help you out.
Dec 31, 2015 | Computers & Internet
Cylinder head to engine block torque sequence and ft lbs
    images for Cylinder head to engine block torque and ...
    More images for Cylinder head to engine block torque and sequence
    Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
    boxwrench.net/specs/chevy_sb.htm
    their specs. Click Here! 3/8 Connecting Rod Bolt, Engine Oil, 45 ft-lbs. 11/32 Connecting Rod Bolt, Engine Oil, 35 ft-lbs. Cylinder Heads. Engine oil. (blind hole).
    [PDF]
Nov 29, 2015 | Cars & Trucks
Toyota 2c. I need cylinder head and flywheel Torque settings
Toyota 2c ...
USE NEW BOLTS...
Torque sequence:
You're driving a diesel single cylinder head engine. Engine head torque has to be done in specific order and stages if not can warp head or break bolts. Suggest you get torque sequence and torque specs from your Toyota dealer, they can give you correct answer. Don't trust answers on here, if you choose wrong specs. could end up messing up head.
Flywheel - Use a Sealer on bolt, Manual Transmission 88nm/65 ft lb... Auto Transmission 74nm/55 ft lb
Aug 06, 2014 | Cars & Trucks
I need too know the torque specs on head bolts and crankcam 2.4 engine
on a 2002 2.4 engine head bolts are 'torqued to distance'.
First, install all the bolts, and, in a sequential fashion, starting at the innermost, working outward, torque all bolts to 70 N-m/806 kgf-cm/58 foot lbs.
Next, mark the front side of each head bolt with a dot of paint. Retighten the cylinder head bolts 90 degrees, starting at the inner 2, and working outward.I dont thin anything has changed on this engine since then.
Mar 19, 2013 | 2005 Toyota Camry XLE
Error fs or f5
Here is the LG LRSC26930TT Service Manual=> HERE When using this manual scroll to page 28 in the PDF. Code fS is #1 abnormal Freezer Sensor, Freezer Sensor Short Circuit. Most likely the sensor needs replaced yet test can also be done to prove this fault as you read from Service Manual what and how to test. I will be here to answer any questions you may have. Here is a location=> LRSC26930TT Freezer Section part location 400A Sea Breeze
Part=> LRSC26930xx Freezer Sensor/Thermistor
I will be waiting should you have other Technical questions, Thanks, Sea Breeze
and Thanks, For Using Fixya
Jun 03, 2011 | LG LRSC26930TT 36" 25.5 Cu. Ft....
What is the torque spec's on a acura integra gs 90 motor ?
1990-1991 OBD0*
Engine: B18A
Cylinder Arrangement: Inline 4 Cylinders, Transverse
Type: Water cooled, 1.8L, 4 cylinder, 16 valve, DOHC
Displacement: 111.9 cu in (1834 cc)
Bore & Stroke: 3.19 in x 3.50 in (81mm x 89mm)
Compression Ratio: 9.2 : 1
Valve Train: Double Overhead Camshafts, Belt Driven
Fuel System: Programmed Fuel Injection (PGM-FI)
Horsepower: 130 hp @ 6000 rpm
Torque: 121 lbs.-ft. (16.8 kg-m) @ 5000 rpm
Redline: 6500 RPMs
Engline Block: Aluminum Alloy with Cast Iron Cylinder Liners
Cylinder Head: Aluminum Alloy
Jun 24, 2010 | 1990 Acura Integra Hatchback
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Garden Logo
130 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
