Refrigerators Logo
Richard Merrow Posted on Mar 27, 2015
I have a Kenmore refrigerator model 795.7102. The freezer on the bottom wil not go below 20 degrees. The refrigerator will be at 40 degrees. Something is running all the time.
  • John Tripp
    John Tripp Mar 28, 2015
    Hi Richard Merrow , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? If you move things around inside the freezer so you can clearly see the rear wall is there frost buildup along that freezer wall. Your freezer does not had a defrost timer the defrost is controlled by a circuit board. There are about four things I want you to check for me so that I may help. I will be looking to hear your response, J.T.
  • Troy Sewell Dec 14, 2017
    I am having the same issue with mine but not icing up I pulled it apart and checked but it's the model
    795.7102.2010 Having same issue with it not going under 40 degrees and freezer is 33ish I have cleaned the coils and noticed 7 flashing lights that repeats over and over next to the compressor in plastic covered box! It seems like it just keeps running! Checked fans and compressor and all seem to stay on 24/7 but not cooling properly!
    PLEASE HELP?????
Charles Airy
Level 1:
Habit-Forming:
New Friend:
  • Contributor 17 Answers
  • Posted on Mar 28, 2015
Charles Airy
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
17
Questions
0
Helped
7998
Points
71
It's possible that the defrost timer motor has stopped. (note your timer might be incorporated in an electronic control module) This will cause the evaporator coils to ice up. Less likely: The timer may be OK, but the defrost heater assembly is open circuit and therefore not heating up. According to RepairClinic.com, 795.7102 model number is incomplete: "795.7102 is a partial model number for a Kenmore Refrigerator. To see specific parts for your Refrigerator, please choose your exact model from the list above or choose the model that's closest." Here a link:
Kenmore Refrigerator Not Defrosting
Testimonial: "Thanks, that is helpful. The complete model number is 795.71023.012 I'll check the continuity of the defrost heater."
Kenmore 596.69142992 bottom freezer temp fluctuating from 10 to 40 degrees. Refrigerator maintains steady 40 degrees. No ice on coils.
The freezer temps fluctuate that much, I am thinking your cold control is going bad... Kenmore Refrigerator Temperature Control Thermostat W10752646
You can clean the fridge with warm soapy water and/or a hand steamer
Kenmore elite refrigerator freezer and fridge too cold
947f1e38-158a-4e1c-9e57-08343605a6a0.jpgKenmore uses a model number like this example=> 321.1234567 and can be found around the fresh food section door frame. I need that model number to see what parts may be causing the refrigerator to be too cold. Let me know and I will do my best to help solve this, Thanks Sea Breeze
Wide variation in temperature in refrigerator section (40 degrees in top, 20 degrees in bottom, also, freezer set at WARMEST setting is ten degrees below zero.
Amana refrigerators older than 5 years have both a cold control and freezer control. this may be your problem. But check both the gaskets on the doors and check for heavy dirt on condser coil. Both can cause wild temp problems. Hope this helps
I have a kenmore refrigerator model 5533360 the freezer will not cool below 20 degrees.
check the back wall of the freezer. If there is frost on it then your fridge is not defrosting. Either the defrost timer, heater or thermostat. Is the fan in the back of the freezer running? if not then is obstructed, stuck or burned out.
Freezer went crazy!!! help
I'm sorry but I cannot find an RF26V model could you double check the model? Sea Breeze
16helpful
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
