The hot water runs perfect when i turn the tap on but if i touch or adjust the tap to either close the pressure or add more, the water turns cold???? Help please
    Top Expert:
  • Washing Mach... Master
  • 48,555 Answers
Odd that you think you need to adjust we have never turned ours off except to replace unit in 50 years. does it do that at other water locations also .kitchen bathroom
Posted on Mar 27, 2015
Have grundfos jp4 with controller. it will start up in the night when no taps turned on,? and to me it appears to have less pressure when using the hose? is there a pressure adjustment
No pressure adjustment.
Air bubbles in line will decrease pressure... air vent at highest point can help solve problem.
http://waterheatertimer.org/Repair-water-heater-valve.html#air
Possible leak problem on Hot line somewhere, and/or pressure problem.
Turn off all taps and check before and after result on water meter.
If toilet is running it draws cold water... but if you have bad single-handle faucet cartridge, it can draw hot into the line.
Following links have troubleshoot resources:
http://waterheatertimer.org/Low-water-pressure.html
http://waterheatertimer.org/Crossover.html
Oct 21, 2017 | Grundfos Plumbing
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
Hi i have installed a few bosch gas geysers at our lodge in mozambique.The problem is that the water gets hot when we turn the water on then the heat just shuts off and the water gets cold after a short...
The problem with all that type of water heater is that once the hot tap is turned on sufficient flow must be maintained through the water heater to keep the main gas burner alight. If the heat adjuster is turned up to high, then the person using the hot water will turn it down to a low rate which means the main burner will turn off and result in cold water. Try setting the heat control to the lowest setting that still gives hot enough water. If you have a thermometer adjust control for a temperature of around 50 to 55 degrees Celcius. You may have to fiddle with fine adjustments to get the temperature and flow rates to maintain a constant output of hot water. You may still have intermittent problems. If the heater only supplies baths or showers you could set the temperatuer even lower (45 to 50) to ensure that the hot tap is used more than the cold which will maintain flow and therefore heat.
Nov 22, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Water heater shuts off when the cold water is turned on
Not sure but check the inlet water at the heater, the filter may be clog up a little that restrict the flow. Did u use the heater at all during the winter? If not, the heat exchanger may be clogged with built up in there. U need to descale it. Good luck. Chinhcu
Mar 31, 2017 | Bosch Water Heaters
I had installed a shower mixing valve with single lever and I had only cold water running and I wanted to test and did not work. does the shower only works when you have hot and cold water running
u have to adjust your anti scold to add more hot water most shower valves are shipped with cold adjustment primary. if still have install paperwork it will tell you how to adjust anti scold if not a remove the lever and u should see a red and blue plastic washer looking tabs those are your hot and cold adjustments slid the red one out and turn it a little counterclockwise and slide it back in place do this a couple of times till u get your hot water the temp u want
Sep 24, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
Mixer tap makes a noise like a fog horn when cold water turned on
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Feb 04, 2009 | American Standard Plumbing
Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Home
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
