Question about Water Water Heaters
I have a new water heater tank with my older beckette burner and honetwell L4103 aquastat. How do I wire in the new L7103 control that came with the tank?
Tip
How to Change the Gas Valve and Thermostat on a Hot Water Heater
<p>If you are having<b> trouble with the temperatures</b> of your <b>gas hot water heater</b> fluctuating too much, or after <b>changing the thermocouple</b> of your gas <b>hot water heater</b> then you may need to change the complete <b>gas valve and thermostat assembly</b>. Also if you have changed the <b>thermocouple</b> and the pilot still will not stay lit, then the gas valve could be bad or the <b>ECO (Emergency Cutout)</b> may have activated and is open. This is a onetime device and cannot be replaced.<br /> <p><br /> <p>These instructions are for the older style <b>gas valve and thermostat combination</b>. These commonly have a large red knob that adjusts the temperature of the water. Also note that the burner tube nut for <b>natural gas</b> is right hand thread, but if you have <b>LP or propane gas</b> the burner tube nut is left hand thread.<br /> <p><br /> <p>The newer <b>gas valve thermostat combinations</b> that have come out recently are similar, but they have a well in the tank that the sensor slides into. The assembly is held fast with a set screw. With this type of <b>gas valve and thermostat unit </b>the tank does not need to be drained, but most of the rest of the change out is similar.<br /><br />To change a <b>gas hot water heater thermostat</b> you will need to first buy a new gas valve for your <b>hot water heater</b>. The <b>gas valve</b> and the <b>thermostat</b> are integrated into one unit.<br /><br />To <b>replace the thermostat on a gas hot water heater</b> you must follow these procedures....<br /><br />1. Turn off the incoming water and<b> drain the hot water heater</b>.<br /><br />2. Remove the <b>pilot tube</b>, the <b>burner gas tube</b> and the thermocouple from the gas valve. Turn off the <b>gas line</b> and remove from the gas valve.<br /><br />3. Get a <b>pump pliers</b> or a<b> wrench</b> in behind the gas valve and turn the whole assembly CCW to remove it from the tank.<br /><br />4. After applying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the <b>ECO</b>. They are the little red wires on the back. If you break them the assembly is irreparably damaged.<br /><br />5. Reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.<br /><br />6. Fill tank with water. Make sure to open a <b>hot water faucet</b> and <b>purge all air from the tank.<br /><br /></b>7. <b>Check for leaks</b> where the gas line hooks up with soapy water.<br /><br />8. Relight pilot light and check operation.<br /><br />9. Set the new temperature setting to a medium setting and then adjust the temperature to your liking from there and adequate time for heating completely<br /> <p>
on Feb 25, 2011 | Water Heaters
I can not turn my pool heater off, nor I can not control my temperture up or down
Remove the wires from the thermostat and see if it shuts off, if so replace thermostat/aquastat.
Apr 28, 2016 | Pentair Master Temp Pool Heater 400,000...
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
Want to raise the water temp
Stand alone water heaters have temperature controls in different locations.
Most residential electric water heaters operate on 240 volts. Please, shut off power first whenever you need open or remove panels for adjustments or servicing.
"Traditional" electric water heaters have them behind removable panels - like the top and bottom gray panel on the water heaters on the right side of the photo. Both panels have adjustable controls behind them and both should be adjusted to the same setting.
Some newer electric water heaters use electronic controls. These may be accessible without removing panels and even have digital displays. Others have controls that are located on the top of the heater - behind a panel. Electronically controlled water heaters may or may not need to be powered on when making adjustments. Check your manual if in doubt.
Gas (propane & natural gas) type water heaters have the temperature control on the gas valve. There are often two controls on the valve, one for the pilot (off, light and on positions) and a second for temperature adjustment.
A tankless water heater built into your home's furnace is controlled by an "aquastat". An aquastat is a fancy term for a thermostat to control water temperature. A typical aquastat is mounted directly on or very near the furnace and looks like this:
Inside, are several temperature settings. Here's a photo of the interior of the Honeywell aquastat:
The Hi dial should never be set to a value lower than the Lo dial. "Safe" settings are Hi = 180, Lo = 160 and Diferential (above "Lo") = 10. You'll need to tweak these up a bit to make water hotter. You should read more about settings for these aquastats here. Skip down to the section titled "What Settings To Use on a Heating Boiler Aquastat Combination Control"
I hope this helps & good luck!
Nov 22, 2012 | General Electric GE SmartWater Household...
I have a model 640 Reliance water heater. SN # A07A150454 M,F, 01/30/2007. About 3 months ago the water started getting cooler, then won't start. I turn the control up, then it starts, but the...
I believe 640 is typical tank-type atmospheric-vented gas water heater.
Gas water heater problems can get complicated. New heater sells for $350 at local box store.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
If thermostat is not controlling temperature accurately, then (1) gas control needs replacement (2) water heater has sediment build-up (3) combustion and burner parts need cleaning. (4) All three things above, plus additional causes such as bad venting or not enough combustion air.
Usually recommended that plumber replace gas control valve thermostat:
See typical tank-type thermostats:
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Clean sediment out of tank:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Clean combustion chamber and burner parts and troublehoot venting and air supply:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Aug 07, 2011 | Reliance Water Heaters
Water heater runs for 40 seconds or so and stops, smell oil oder
Hello STOP!!!!! don't push the reset button any more.You have a ignition/spark problem.You will load the chamber with oil and will cause major problems when it lites off.Replace the ignition TRANSFORMER on the burner.Avalible for (beckett burner) at home depot/lowes.
Sep 20, 2010 | RTO Bock Water Heaters 51E 50 gal 152,000...
ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Sep 28, 2009 | Amtrol ST-120V-C THERM-X-TROL ASME...
Beckett home oil burner
problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Nov 01, 2008 | Water Heaters
Water Heaters Logo
41 people viewed this question
Top Water Heaters Experts
D. E. Hev
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
