Question about Valor Car Audio & Video
Need to know the wirering diagram wire for wire
The plug on the back of the unit
landsend
  • 1066 Answers
SOURCE: spark plug wires
the firing order is stamped on the intake manifold.  next time replace them one at a time.
Posted on Mar 26, 2009
farfield
  • 462 Answers
SOURCE: need wiring diagram for 1980's 3 ton package unit
I assume you know if this is correct voltage and single or 3 phase, and whether it will fit your application or not, how is the duct work going to attach, how many people will be in the conditioned area, what is the building made of, how much insulation is has...
A little more to it than just "turn it on".
If you get the models and serial and can contact the manufacturer or their representative you might get a wire diagram. Most any package unit would do. As long as you keep the original equipment controls. If you "patch" it up it may be hazardous by not having safety's where it was designed for. Or for instance It may have a anti freeze thermostat. By passing this could lead to coil freeze up and compressor damage. Leaving out a pressure switch (if any) may do the same or could become dangerous to people in the event of fan motor failure. A low temperature fan speed switch may not be needed now unless you plan to run the AC in below 55'f.
And a few dozen other factors that might need to be considered.
If you feel confident after this then contact carrier.
Please rate me as high as you can and thanks for using fixya.
Posted on May 19, 2009
  • 122 Answers
SOURCE: i got a stock ford JBL amp with no wiring diagram
ok on most amps there are two sets of wire ports one for speakers & one for +12v,grd & 12v remote start if you look over each port it will say what port is for what wire if it is in a connector it gets slightly more complecated what you do is with a vm check from wire to chassis ground [like seat bolts] 12v with key off when you cet power isolate wire then turn key on till radio comes on then do the same test for 12v isolate that will be remote start then turn key off &check from the first wire to other wire for ground to find speaker wires connect a regular peace of wire to chassis grd & touch the wires you will here the speaker pop be sure not to hold the wire on long cause it will blow the speaker
Posted on Jun 04, 2009
  • 4874 Answers
SOURCE: I need the pin (plug) wire diagram
http://www.tehnomagazin.com/Auto-radio-car-connector/PIONEER-Car-Radio-Wiring-Connector.htm
Posted on Jan 09, 2010
Testimonial: "good job...many thanks for all the help. "
ZJLimited
  • 17970 Answers
SOURCE: removed spark plug wirers need firing order Ford Expedition 1999
Several engine sizes there...
1999 Ford Expedition 4.6 liter SOHC V-8 VIN "6"
1999 Ford Expedition 4.6 liter SOHC V-8 VIN "W"
1999 Ford Expedition 5.4 liter SOHC V-8 VIN "L"
Hope this help to solve it (remmeber comment and rated this).
Posted on Apr 20, 2010
How spark plug wirers go on motor from coil
The two short wires go to the center cylinders, two long to the outside cylinders. You will need the diagram to figure which coil wire goes where if you were unfortunate enough not to have marked them.
Aug 15, 2014 | 1994 Honda CB 750 Nighthawk
Need to wirer kenwood kdc-hd545u radio to my 1999toyato avalo and the wirer harness has been cut off the toyato need wirer diagram to match wirer colorsto make it work!!
1999 Toyota Corolla Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Oct 14, 2012 | 1995 Toyota Corolla
I need the ac wirering diagrahm 4 a 12 volt 180watt profile 5 power plug (6 pin)
first you need to learn the proper name of the plug or conection once you have that name googel
said name and "wiring diagram"
Feb 21, 2010 | Gateway Profile 5 PC Desktop
Where can i find info on a comfort air air conditioner. Model# REG183A I need the wiring diagram for the compressor.This is the second unit I have bought, and it too has melted the wires on the...
If it is a 220v split unit you dont have a problem you just have to follow the wirering from the indoor unit and you will get the L1 L2 sign on the log or you might see L1 and comp L2 will go for the run side of your compressor from your capacitor and L1 for the common on your compressor but after everything is straight forward
Nov 05, 2009 | Heating & Cooling
I need wiring schematic
I bought a cbr 600 , but bike came with the wirers not connected. Rectafire, was also not connected? need diagram or help really badly!!!!
Jun 26, 2009 | 1994 Honda CBR 600 F(2)R
I need to Know the wirering for the VRX755VD
follow this link http://www.crutchfield.com/p_020VRX755/Clarion-ProAudio-VRX755VD.html?search=VRX755VD&tp=20217 look halfway down the page and click on download owners manual it will also have the installation manual on there for the wiring diagram.
May 22, 2009 | Clarion VRX755VD Car DVD Player
Promblem wiring to my car
GO TO WWW.CRUTCHFIELD.COM AND THEY WILL SELL YOU AN ADAPTER SO YOU DON'T HAVE TO CUT ANY WIRES ON YOUR CAR
Jun 19, 2008 | JVC KD-SC800 CD Player
Car Audio & Video Logo
65 people viewed this question
Top Valor Car Audio & Video Experts
David Payne
David Payne
steve morris
steve morris
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
