Question about Ovens
Oven turns on and lights up but does not heat up?
    Top Expert:
  • Ovens Master
  • 44,451 Answers
Check the element by golly
Posted on Mar 27, 2015
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
Fisher Paykel double oven light and heat won't shut off
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Mar 13, 2015 | Fisher and Paykel Ovens
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
Oven wont turn on,preheated light keeps flashing when turned on
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 15, 2011 | Ovens
Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Nov 24, 2009 | Ovens
Oven light (surface heating) won't turn off
it is normal for it to stay on until the glass gets below 110 degrees it is for safety reason
Oct 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Main oven doesn't work
it sounds like your gas valve isnt opening
Jun 12, 2009 | Ovens
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
