Question about New Home L-373 Mechanical Sewing Machine
My bobbin thread bunched up and the hand wheel won't turn
    Top Expert:
  • New Home Master
  • 44,327 Answers
Hate that when it happens start at the bobbin and start cutting thread all the while trying the hand wheel forward and back . it will all come out eventually
Posted on Mar 27, 2015
The hand wheel does not move. removed the needle, still not working
sounds like you have thread bunched up in the bobbin case. take out the entire bobbin plus the bobbin holder and clean it. it is worth a try....
May 20, 2016 | Singer 4411 Heavy Duty Sewing Machine
How do I add thread to the bobbin on Singer sewing machine 3114?
Your repair shop will have to fix the handwheel, but you can still wind your bobbin. UNTHREAD the machine completely, and take the needle out. Set up your thread to wind the bobbin, and push the winder over until it clicks. Wind your bobbin. I don't have a picture of your model; this is just standard.
Feb 23, 2015 | Singer Sewing Machines
Why does my thread keep bunching up?
That is called "thread nesting," and several things can cause it. The upper thread enters the bobbin area during sewing, catches the bobbin thread, and as the needle goes up, pulls the stitch tight. Something is catching the upper thread as it goes around. The most common reasons are the bobbin or bobbin case (or both) is improperly inserted; the bobbin is warped (roll it down a flat surface--if it wobbles, it's warped), either the case or the bobbin is not seated evenly, there is a rough spot on the bobbin case that is catching the thread, or your bobbin is loosely/badly wound. You need to rule out the possibilities step by step until you find the cause. First, review your threading procedures from start to finish, using your user's manual. Then, without fabric, turn the hand wheel by hand (ALWAYS towards you) to see if you can see it start to catch. The top thread should rotate smoothly in the bobbin area. You should be able to pin-point the cause that way.
Sep 24, 2014 | Singer 2517 Mechanical Sewing Machine
Thread bunches up when replacing thread on bobbin
If the thread is bunching or tangling when winding a bobbin, check that you have properly threaded the winder. Especially make sure you are running the thread through the bobbin tension assembly.
Aug 21, 2014 | Singer 5050 Mechanical Sewing Machine
Makes one stitch then abrupt stop with threads bunching up from bottom
Have you taken the bobbin out and made sure there is nothing caught in the bobbin race area. Maybe even unscrew the plate and take the whole bobbin race assembly apart and clean well. Once that is done put back together then re thread machine. Next I would start by hand turning the machine and doing some stitches slowly with the fly wheel make sure to to forwards only never turn the fly wheel back wards. If everything seems clear give it some power slowly and see how it goes.
Feb 11, 2014 | Singer 9960 Quantum Stylist Sewing Machine
Hand wheel won't spin?
Something is binding up inside. Clean and check under the presser foot and bobbin area. Really examine under there... look for threads wrapped around and in between moving parts. Also check in the slot for the take up lever... sometimes threads get balled up inside there can cause problems.
could also be a bent upper arm inside the machine (lets hope not) Get professional help if cleaning doesn't free it up.
Aug 02, 2012 | Singer 57815 Mechanical Sewing Machine
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    The thread hangs up inside the bobbin holder
    A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
    Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
    I was doing fine zigzag, ran out of bobbin thread did not change any thing and now the thread bunches on the bottom and the machine does not advance. Bobbin casing pop up also this is a 774 model
    Well The most probable cause of the lower thread breaking is an improperly wound bobbin. Regardless of where you wind the bobbin, inside the machine, on the top of the hand wheel or on the front side near the hand wheel, the basic "bobbin" rules apply.
    ** Always start with an empty bobbin. Never wind one color over another color.
    ** Don't wind the bobbin so full that it would be tight and hard to insert into the bobbin case. Most machines have an automatic "shut off" when the bobbin gets full, but if yours does not, be careful not to fill it too full.
    ** Wind the bobbin evenly across and in level layers.
    ** Never mix different sizes of thread in the bobbin and on the spool, unless you're doing sewing machine embroidery or some specialty type of sewing. Using different weights of thread on the spool and in the bobbin for general sewing will cause ragged stitches as well as other stitching problems.
    So clean all the threads and do it work from start.........
    Please reply ......
    Thanks
    Dec 29, 2009 | Singer Sewing Machines
    New Home L-373 Mechanical Sewing Machine Logo
    63 people viewed this question
    Top New Home Sewing Machines Experts
    Tally Girl
    Tally Girl
    navapistol
    Level 1 Expert
    Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
