Question about Microwave Ovens
What size fuse does the micro wave take an what the size of the star wrench to remove the outer case of the cabinet
MicrowaveSvc
  • 9085 Answers
SOURCE: MICRO WAVE RUNS BUT IT DOES NOT HEAT
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part such as high-voltage rectifier diode
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 05, 2007
  • 13 Answers
SOURCE: RE: Sharp R 1870 F
yes its possible
Posted on Jan 02, 2009
SOURCE: need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Posted on Dec 18, 2009
  • 1015 Answers
SOURCE: Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Posted on Dec 24, 2009
  • 10865 Answers
SOURCE: outer door frame cracked
Hello. That frame is decorative only so you need not worry that there is a radiation leak. You may be able to order a part for it or you may be able to use some clear epoxy and a couple of furniture clamps to repair it. It you choose a clear epoxy get the 5 minute type as that will give you time to position the clamps. The 1 minute won't give you enough time.
Posted on Mar 11, 2010
Can magnetron be replaced without removing microwave?
Hello
There is no way u can replace mag without removing micro and placing on desk !
There r screws on the side and or behind the outer cover.
The mag maybe ok but the transformer or a common fuse , or rectifier gone bad .
Can to take a picture front and side of the micro location ?
Nov 12, 2014 | Microwave Ovens
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
The micro wave just lost all power and won't turn on. Its plugged in.
Hello :
It seems that there's a problem with the power transformer or the power PCB . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
CAUTION: a microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Please rate !
Jun 08, 2010 | Maytag MMV5207A Microwave Oven
Change fuse on model#jvm1631bb002
Take the outer case off that reaches from one side over the top and to the other side. The fuse is located behind the control touch panel. Back where you will see wires, a capaister, transformer, ect. What your looking for is a fuse that looks just like an old round glass car fuse. It's not one though. It's a fuse made just for micro waves. Where the glass would be it's either black, white or tan. Noramlly it's a 20amp. Good luck.
Nov 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating
Remove the outer cover (pull the power plug first) and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan-like device located within the sheet metal wave-guide near the opening in the cooking cavity where the microwaves come into it). This stirrer has a plastic bearing that frequently arcs over and permanently shorts out the microwaves which blows the fuse. If no blown fuse is found, look for a loose or defective door-interlock micro-switch.
Nov 17, 2009 | Kenmore 61652 Microwave Oven
I have a Sharp micro wave model R-1492. It turns on, but nothing cooks. Do you think I may need to replace the magnatron
first before you replace the most expensive part of the unit,check the h.v. diode and h.v. capacitor, the thermistor on the magnetron tubes outer case side, you will need to remove the top cover to accomplish these things
Nov 14, 2009 | Sharp R-1492 Microwave Oven
The circuit breaker to the micro wave was tripped and when reset the microwave did not work it just hums also the lights and fan does not work. What's up with that?
the hi voltage transformer is still operating, but the rest is dead, you could remove outer cover and see if there are 2 fuses, most only have 1 fuse, sounds like new microwave time
Oct 09, 2009 | Microwave Ovens
Over the stove microwave just stopped working. Circuit breaker was not tripped.
Sounds like the fuse is blown, you will have take the outer case off to find the fuse and replace it
Sep 07, 2009 | Microwave Ovens
Sharp Carousel Model#4A58: was cooking & made
If you have no power what so ever its probably the main fuse inside the mirowave. You'll have to take it apart. If you try this yourself unplug it then there are several screws around the cabinet of microwave remove them and make sure that they go back where you took them out from because they may or maynot be the same size or length. once you get the cabint off follow the plug wire up into the micro wave there may or may not be a fuse on the wire just inside the frame of the Microwave but it will be close when you find it take it out and replace with the exact size take it to a appliance parts store and get the replacement.
Sep 03, 2009 | Sharp R-4A58 Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
