Question about Tablets & eReaders
Nobis model no: NB7022 S keeps resetting to factory when powered on
3 Suggested Answers
mindreader
  • 578 Answers
SOURCE: I have a nobis Tablet.I tried to do a hard reset
guess is that the float level is not closing (need to open float bowl and clean everything inside with carb cleaner. Confirm that the float is operating (up and down) . Reassemble and try again...should be fine.
Posted on May 25, 2014
mike0862
  • 5533 Answers
SOURCE: How to do a factory reset on a Nobis 7.85 tablet, it is blocked
Follow these steps:
1. Press the power button and the home button together or Power button and Volume button together for a while, long enough till the Android boot mode screen appears. Press home button to reach the options under boot mode. Navigate through the options using volume key and select "Wipe Data Factory Reset"option using shortcut menu button. Again navigate to the option "delete- all user data" and select it using shortcut menu button. (Make sure memory card is not inside; otherwise the data on it will be lost). After the data is deleted, a message saying "Data Wipe Complete" appears. Press the shortcut menu button to reboot the tablet again. Now, your tablet is as fresh as a new tablet
Posted on Feb 05, 2015
How do i factory rezet my nobis tablet when its froze and wont go past the nobis emblem screen?
Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    Can you purchase a user's manual for a nobis tablet
    http://www.bidwelltec.com/wp-content/uploads/2014/06/NB7022-S-user-guide.pdf
    this may not be the exact model number nb7022 but you did not specify the model number. Down load it (FREE)
    Jun 07, 2015 | Tablets & eReaders
    How can I get my tablet to work when it turns on and starts to load it doesn't stop loading.
    Lot's of people have your problem. Try Googling *Nobis NB09 stuck on Go*. I happen to have a Nobis NB09 myself and can say with utmost confidence that it is a POS. The problem, from what I've experienced and read is a whole bunch of units with defective internal SD card memory which results in the App partition not being seen or available to the operating system.
    Since the reset button didn't work, there is a small chance a factory reset might work to at least get you into the set-up process so you can check the app partition memory status. I suspect, like mine, it will say 00.0 bytes available. This is the top graph shown in Settings > Storage.
    Anyway to do a factory data wipe/reset do the following: with the tablet powered off,
    1) press and hold down at the same time the power button
    and the volume (-) button. After about five seconds you will see
    the Nobis screen. Continue to hold both buttons down. The
    Nobis screen will go away. Continue to hold down both
    buttons until a green android appears along with green text.
    Release both buttons.
    2) Look at the lines of text. One of them will say something like
    Wipe Data/Factory Reset. Use the volume(+) button to scroll
    to it and select it by using the power button.
    3) another screen should appear with a bunch of *no no no no*
    lines and one line for a go ahead. Scroll to the go ahead line
    using the volume (+) button and engage it using the power
    button. It should then do the factory reset bit and then a
    screen will come up giving the option to power it off.
    4) Power it off, wait at least ten seconds and if it doesn't power
    back on then push down and hold down the power button
    until the Nobis screen comes up. Release the power button
    and wait. Allow the boot up process to run it's course. This
    could take several minutes - up to ten minutes from some
    reports with the GO screen showing. If your unit is not
    completely borked in probably about three to five minutes
    it will finally boot into the set up screen.
    If it does this enter your google email info, etc and it will eventually go to a you are ready to go screen. The first thing you should do is go to Setting > Storage and check out the top bar graph. If it's green all the way across and says 00.0 bytes then your memory
    is defective and your app partition unavailable. If this is the case the tablet won't remember any changes and it won't be able to upload any updates or optional apps. Every time you turn it off and start it back up you will have to again go through the set up process. The only recourse is if it's under warranty to contact Nobis now Bidwell and see if they will issue you a RMA number so your can return it for repair. I did this and they repaired mine and
    returned it. It worked for about two weeks and AGAIN the memory went bad. I tried to get another RMA and they gave me the runaround. So I told them to go take a flying leap and that I'd be letting everybody know their product is defective and they don't stand behind it.
    May 17, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
    My nobis tablet is stuck on the nobis start up screen. How do I fix it.
    If you Google NobisNB09 stuck on GO you will find many angry people who have the same problem. Rarely does the factory reset procedure work to fix it. IMO they have a problem with faulty internal SD chips. So, what I'm saying is you may not be able to fix the problem other than trying to get an RMA and sending it back for repair if it's still in the warranty period.
    Here is the factory reset procedure.
    1) press and hold at the same time both the power button and the volume(-) button.
    2) keep holding them until you see the Nobis screen, Then it will go off. Keep on holding both buttons down for perhaps ten or fifteen more seconds and finally you will see a screen with some green text options
    3) Among the options is one that says something like "wipe data/factory reset.
    4) Using the volume (+) button scroll to it and then press the power button once to select it.
    5) Another screen will come up with text options of no, no no for five or six lines with one that has a go ahead for the reset option. Again, using the volume (+) to scroll to the reset option and select it using one push of the power button.
    6) you will get a reboot option.
    7) reboot by pushing the power button, it will turn off.
    8) Give it a minute or so and then push the start button and
    hold it until you see the Nobis screen. Let it go and wait. If the hardware's OK it will go through the initialization routine which
    should take several minutes. Anything more than about ten
    minutes without going to the set up screen indicates you have
    bad hardware such as a faulty internal SD memory.
    One hint: turn off your wi-fi router so it can't connect to wi-fi.
    It will boot up with the wi-fi ON and it will connect to any open
    router it can find and commence to download updates for all the apps. This makes it take forever and can completely fill
    up the available app partition memory and result in another failure to boot up next time.
    IMO the Nobis NBOP is a POS! I have one so I know.
    Apr 06, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
    Nobis 10 inch tablet , will not turn on
    Greetings sandra
    Here is a link I used to reset a Nobis tablet last month and it worked. Good luck
    Chadman
    https://youtu.be/x6u2qWWeaEM Android tablet pc hard reset reboot
    Mar 25, 2015 | Tablets & eReaders
    Nobis tablet stuck on go
    try holding power button in for like 30 seconds to completely down power tablet
    Jan 02, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
    Nobis tablet froze and won't go past nobis screen
    Do a factory restore, using the buttons on the tablet. The procedure varies but typically it's Hold VOLUME DOWN and POWER buttons at the same time. When (if) you get a menu, choose factory reset. The sad news is she will lose all her pics, music, apps, etc. but the tablet should work.
    Jul 20, 2014 | Tablets & eReaders
    Nobis NB09 has error launching
    i get this when i boot it up unfortunately the process com.google.process.gapps has stopped ok what does this mean
    Jan 29, 2014 | Tablets & eReaders
    Tablets & eReaders Logo
    89 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
