Question about Seiki 32" LED TV - SE321FB
Screen shows not support when using as a monitor with desktop. Cannot change the resolution
    Master:
  • 380 Answers
Depending on your model you might need a update in the firmwar v?rifiy on the constructor web site
http://www.seiki.com/support/downloads.php
Posted on Mar 27, 2015
How do I change the font and icon size on the monitor. I have two monitors and font and icons are different sizes.
Change the Resolution of the 2 monitors to match the setting you prefer. (Right-Click on Desktop, choose "Screen resolution" It should show both monitors.Set resolution on the "Wrong" screen to match the settings on the "Correct" screen.
Oct 11, 2015 | HP W2007 LCD Monitor
Tip
How to resize your desktop background.
If your desktop is smaller than the dimensions of your monitor then follow the following steps to get a full screen:
Setting the resolution:
1) Right click on an open spot on your desktop and select Properties at the bottom of the popup menu.
2) This will then open up the Display Properties window as shown below.
3) Click on the Settings tab (it's to the top right of the Display Properties window as shown in the image below.
4) At the bottom left of the settings tab there is a Screen resolution heading with a slider bar beneath it.
5) Slide this bar to the left or right until you find the resolution you like.
6) The click Apply when you have found the right resolution.
Sliding the bar to the left = lower resolution, larger desktop icons and less quality.
Sliding the bar to the right = higher resolution, smaller desktop icons and better quality.
NB: If you are using a CRT (older screen) the max resolution will be around 1280x1024. Newer LCD screen (flat and thin monitors) can go way up to 1920x1080 and beyond if HD is supported.
NOTE: If when doing the screen resolution changes your screen goes blank after you click Apply then immediately hold down the Enter key to restore it back to your previous settings
If this doesn't work then it just maybe the case that you need to set the auto screen fit function on the monitor itself using the buttons provided on the monitor.
This tip is useful when you plug in a monitor and the screen displays the No Signal or Signal out of Range massages. Simply change the resolution to something the monitor can handle and there you go.
You can also check out my video tutorial if you want to:
on Nov 10, 2010 | Computers & Internet
Tip
How to change your Windows 7 display settings In Windows 7 there are serveral...
In Windows 7 there are serveral ways to get to your display settings. I have detailed them below in options so that you can access them as needed.
Option 1
Right click on your desktop and select "Screen Resolution"
Option 2
1. Right click on your desktop and select "Personalize"
2. Next click on "Display"
3. Click on "Adjust resolution"
Option 3
1. Click the Start button and click Control Panel
Once you are in the Screen Resolution you can set the resolution you want.
Note the resolution that is set now is a wide screen resolution. If you have a standard monitor the equivalent resolution would be 1280 x 1024.
After you have made the needed changes click on Apply then OK to save your changes.
Note if you are still have trouble with your monitor displaying right you may need to install the monitor drives. Windows is not going to have the actual drivers for all monitors. So in picture below you will see where is shows "Generic PnP Monitor" this means that the computer is using a generic driver. You can access this screen by clicking on "Advance Setting".
If you need to install the monitor drivers the link below will take you through the steps of installing the monitor drivers.
http://www.fixya.com/support/r4290666-install_monitor_drivers_in_windows_7
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
Change display properties
To change your screen resolution
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  3. Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
c976c8e1-2a05-4209-a850-ea7c43422c04_50.jpgScreen Resolution in Control Panel shows the recommended resolution for your monitor.
Aug 27, 2012 | Computers & Internet
How can i change screen resolution?
Right - Click on the desktop and go to properties then got to Settings tab and then you will notice the screen resolution aplet where you can change your resolution. If you are using windows 7, just right-click on your desktop and go to personalize. Type Screen resolution on the top right search box... bingo you will be presented with the screen resolution aplet.
Feb 21, 2012 | American Dynamics ADMCA1LCD20W Monitor
Changing resolutions
right click on your desktop. click on personalize. and will show you this: 10e4f11.jpgthen click display settings: c1e4b41.jpg set resolutions using the slide bar. then click apply then ok.
Apr 07, 2010 | Compaq Presario SR1000T (568657) PC...
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
Trying to get the screen size fixed properly. screen needs to be set at 1680x1050. It is making pictures look fat
u need to check if ur monitor is capable of handling 1680x1050...resolution
go to Desktop/right click on desktop/go to properties/settings.../in the screen resolution optopn/do u c a slider than has option to select ur 1680x1050
if it has then chose that and click OK....
if ur monitor can show that resolution it will give ua msg else u wont..
mind it...a higher resolution and change regresh freq rate can spoil ur monitor....
so be careful while doing this
Dec 17, 2009 | Computers & Internet
I connected my laptop to my LCD TV using VGA cable. I changed the mode to VGA external monitor. Image/video appear perfectly fine during start up. but right after windows logged in for like 5 second the...
Easy way:
Press and hold Fn key, and then look at the F1-F10 keys.. Most likely it is F7, and has a picture like a computer screen.
So, press and hold Fn key, and then press F7 (or whatever key it is for your laptop). This will change your "presentation" settings, and thus switch back and forth from laptop screen, laptop screen + external screen (TV), just external screen (TV).
If this doesn't work as you expect, just try:
Instructions for Windows XP:
Open the Display Properties window by:
Start -> Run -> %windir%\system32\control.exe desk.cpl,@0,3
(this is the same window where you can change screen resolution).
There you will see two or more "screens", labeled: 1, 2, 3.
Click on "1", and you'll see:
[X] Use this device as the primary monitor
[X[ Extent Windows desktop onto this monitor
Click on "2", this is your TV.. Mark
[X] Extent Windows desktop onto this monitor
Then change the resolution to 800x600.
Click Apply
=> now your TV should start showing you a picture.
You can move your mouse between the laptop screen and the TV screen.
If you want just the TV, you can make "2" to be your primary monitor, by clicking on [X] Use this device as the primary monitor.
Nov 04, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Seiki 32" LED TV - SE321FB Logo
52 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
