Question about Sharp 52"" aquos lc-52sb55u 1080p widescreen lcd hdtv - 16:9 10000:1
Trying to connect pc with hdmi cable have great picture no sound on TV Used HDMI imput 7 tried imput 6 with hdmi and audio imput from PCF to TV still picture and no sound any suggestions
  • Sharp Master
  • 3,289 Answers
Hi Scott,
On your PC, you'll need to go into the Control Panel --> Hardware & Sound --> Sound (Windows 7) and click on "Playback". Here, you'll need to change the sound settings to reflect the audio to be handled by the video card / audio chipset / HDMI jack on the motherboard. You should also check for other settings such as Digital Output that are usually associated with and HDMI jack on the card and not an analog jack.
As it is now (or is likely to be the case anyway) the picture is being handled by the HDMI on the video card / motherboard; but the audio is still coming from the the speaker jack(s) on the motherboard or audio card. Making the changes above will redirect the audio from the speaker jack(s) to the HDMI jack instead.
Posted on Mar 27, 2015
Testimonial: "Thank you for your assistance it was very helpful, solved my question."
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
Jul 05, 2013 | Hitachi 51F510 51" Rear Projection...
I have an ACER AX1700 which I connected to my TV with a HDMI cable. I get no picture and no sound. How do I get the pc to recognize the TV through the HDMI cable. I have checked the display settings and it...
hi to get picture plug in the hdmi cable into tv and pc then press FN key plus the key that has a picture of one or two tv screens along the top of the keyboard and i think for sound you will need an audio jack 3.5mm cable to connect to tv and the mic jack on your pc..im running a vga on my pc to vga on my tv and i needed an audio cable for sound or you might want to select your menu on your tv and select pc or hdmi not sure though thats what i do and it works great...hope this helps
Aug 07, 2010 | Acer Aspire AX1700-U3793A PC Desktop
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
I have a Westinghouse model SK-26H730S. I have my pc hooked up to it with hdmi cable. I'm trying to run the sound through the tv so I can use the remote. I tried going through the 1/8 mm jack, no good. I...
Hello, when you are using HDMI you should not use any other connection to hear audio on the TV, the HDMI cable has the audio built in. What you need to do is to make sure you have some king of audion coming out of the pc and raise the volume on the TV. If you need further or more detailed troubleshooting please email me at westytech@wde.com so we can get in contact. Please rate my help on this webpage if this information has been helpful.
Nov 11, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
Apr 10, 2008 | Sony BRAVIA KDL-40V3000 Television
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 52"" aquos lc-52sb55u 1080p widescreen lcd hdtv - 16:9 10000:1 Logo
115 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
