IP address resets to factory default when saved after a change.
  • 3,289 Answers
Make & model router?
Posted on Mar 27, 2015
Deracam will not reset. How do I get it to reset?
If you want to reset your IP Camera to factory defaults, you can use the following 3 methods. After resetting the device you will lose all your settings except Client Settings.
Method 1:Hard reset/ By pressing the RESET button
Step 1- Keep the device powered on for at least 30 seconds to complete its normal startup.
Step 2- Find something like a pin to press the Reset button on the camera and hold it for 15 seconds to restore the settings to factory defaults.
Step 3- Afterwards release Reset button, and the camera will be restored to factory defaults after rebooting.
Note: Reboot process takes about 1 min, please be patient.
Method 2:By using Intelligent IP Installer
Step 1- Install the Intelligent IP Installer with the CD.
Step 2- Run the Intelligent IP Installer. Click Search to find your device.
Step 3- Select your Camera in UPnP device list, click Factory default on the right side.
Step 4- Type the username and password in the login page, the default username and password are both admin. Wait for the device to reboot.
If you changed the username and password before and forgot the username and password, you have to follow
Method 1, make a hard reset.
Method 3:By using Web-based Utility (management page)
Step 1- Open the web browser and type the IP address of the IP Camera into the address bar, press Enter. If you have changed the default port number is 80, Then type the IP address of the camera: new port number into the address bar of web browser.
Step 2- Type the username and password in the login page, the default username and password are both admin. Then click OK to connect to the device.
Step 3- Click SETTING -> BASIC -> Initialize on the left side, and then click Factory default to reset this IP Camera to the factory default settings.
Step 4- Keep waiting until the progress bar shows completion.
Feb 04, 2018 | Miscellaneous
Resor factury shdls router ct524(hardwair)??????No reset button on the back of the modem!!!!!!!!!!!!
The factory reset is completed via the configuration page. Enter the IP address of the router in your browser and then login. For
example, if the IP address is 192.168.1.1, enter http:// 192.168.1.1 Look for Erase and Reboot and click to reset to factory defaults. Caution! If you reset your device to the factory default, any changes to
parameters will be lost and all parameters will revert to their default values.
Try root at the default username and password unless it was changed. (or root and 12345). I am not aware of a hardware factory reset i.e. pin hole.
Dec 17, 2014 | Computers & Internet
There should be four sets of numbers each seperated by a dot. These are the address of your router which will allow you to configure the router as you wish. Follow explanation below.
Broadband router manufacturers generally allow users to setup and configure the router settings through their web browsers. You just have to connect the browser to your computer and enter the default private IP address in the address bar of your browser.
The default IP address is factory set and is usually begins with 192.168. Some of the popular brands as given below use 192.168.1.254 as their default private IP Address.
  • some 3Com OfficeConnect routers
  • Netopia / Cayman Internet gateways
  • Billion ADSL routers
  • Linksys SRW2024 managed switches
  • Westell modems for Bellsouth DSL Internet service in the U.S.
192.168.1.254 Router Password
Alongwith the default Private IP Address, these manufacturers also set a default username and password. Users are allowed to change these default password settings. But in case they forget the changed admin and password details, they can use the hardware reset button to change all the settings to the default settings. In this process the password is also reset to the factory default value
Dec 17, 2013 | Dell Computers & Internet
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' sales@internetvoipphone.co.uk ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
How to reset netgear wgr614 to factory default
You can reset your Netgear router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings. For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Get instant Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Jul 26, 2012 | NetGear WGR614 Wireless Router
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
Change the local IP address of Billion 400G
You need to login to the router page with the IP 10.0.0.2 and the on that and you can change the IP from that page
On login it will ask for username and password it is admin and password is "password" by default if you have any issue in getting user name and password you can reset the router as below
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
it will come back to factory settings of 192.168.1.1 and then you need to configure the router as per your internet service provider
you can check the manual at the below link
http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Nov 27, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Cant accses router
Pressing and holding the reset button on the router for about 5 seconds should reset the router, but you may need to connect with the router via an RJ45 network cable incase the wireless is not able to set it up The default ip address of the router should then be 192.168.2.1. do not use the windows repair wizard as this totally messes up your pcs ip address, make sure that your network wireless and wired adapters, are set to obtain an ip address automatically You shouldnt change the PPOE or PPOA settings, as they are the settings on which your ISP allows your router to connect to the server. Manually entering an ip address will effect the address of the router so keep the settings as enable DHCP to assign ip addresses automatically. Ensure when you have it running you save the settings so as you can reinstall them if neccasary.
Aug 20, 2007 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
