Question about Sennheiser HDR 120 Consumer Headphones
Why don't either the charging or on/off lights come on when my transmitter is plugged in?
The headphones are turning on just sending static.
  • 2,963 Answers
Bad connections. Plug in and withdraw multiple times, It may serve to "clean" and polish the contacts. Hope it works.
Posted on Mar 27, 2015
Work fine for about 5 minutes than change to static
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting and shouldn't just cut out to static.
Jun 25, 2014 | Sennheiser RS 120 Consumer Headphones
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
I have a huge problem with these headphones (the Sennheiser HDR 120)... and my wife bought two of them... They have great sound on the computer, but once the green light turns off on the base? There...
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
Aug 12, 2011 | Sennheiser RS 120 Consumer Headphones
My Sennheiser RS 110 headphones won't work. I followed the installation directions but all I get is static. What else can I do?
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
Jan 02, 2011 | Sennheiser RS 120 Consumer Headphones
Need instructions for wireless headphones
Plug the red and white cables from the transmitter on the headphone set into the red and white slots for audio out on the TV this will supply the sound to the transmitter which in turn send it to the headphones. The transmitter must also be plugged in to the wall outlet for them to work, and batteries in the headphones must be good.
Nov 24, 2010 | Televison & Video
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
No charge for xbox wireless headphones
There should be lights on the front of the headset's transmitter box. Are these lit up?
Also, there should be a "palm tree" icon on the left earcup of the headset. When you turn on the headset from the POWER button, the palm tree should flash about once a second. Is it flashing?
If not, you may need to "pair" the headset to the transmitter.
Mar 17, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Dec 16, 2008 | Sennheiser RS 120 Consumer Headphones
Logitech Freepulse headphones won't turn on
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
Nov 25, 2008 | Logitech FreePulse Wireless Consumer...
Sennheiser HDR 120 Consumer Headphones Logo
274 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
