Question about TruTech PM1919BXA1 19 in. LCD TV
The TV will not respond to the remote control unless it is very close and in a certain place. How can this be fixed?
  • TruTech Master
  • 3,289 Answers
The first thing to do is determine if it is a problem with the remote's transmitter or the TV's receiver. To do that, you'll need a different remote capable of controlling the TV. This can be a replacement universal type, one borrowed from someone with the same TV - or bringing your remote into a store that sells these TVs (and has them on display). Try to control the display TV with your remote.
If you can work the store TV with your remote - then the problem is with your TV. If you can't work it - then either the TV will not respond to your remote due to being a different model / year / etc. (this does happen from time to time) or you've got a faulty remote. Before leaving the store - look for a universal remote. RCA and others make them and they can be had for under $20. Check the packaging to see if your TV is compatible and buy it. Save your receipt.
Bring it home to see if it can be programmed for your TV. If your TV is supported but it fails to control the TV - the problem is likely to be with your TV. If it does control the TV, the problem is likely to be with your original remote.
I do not recommend opening the TV to try to "fix" it. Bring it to be serviced or deal with it another way (cable box, etc.). If it is the remote - which I suspect - you *may* be able to open the remote *carefully* and see if the LED behind the red plastic lens is aimed away (from dropping, etc.). If it is - bend it to point straight out of the remote and reassemble. If it works - bring the new universal remote back for a refund. If it doesn't - toss the old remote and use the new one. :-)
Posted on Mar 27, 2015
  • TruTech Master
  • 2,253 Answers
Check that the batteries are new and fresh
check that there is nothing in front of tv blocking signal from remote
check that remote is pointed directly at tv and that it is clean with no foreign material on the head of it.
if none of the above helps, try unplugging the tv and then plugging it back in.
good luck
Testimonial: "Thanks for the input. We did try a different remote and the different remote doesn't work the TV at all (even though we tried to program it). I'm afraid it is the TV."
How to remove code set 3 for the remote control panasonic bd-45
It seems the best way to "remove code set" is to overwrite it with a different code set.
(From the Owner's manual for the Panasonic DMP-BD45)
STEP 6 :
Reprogramming the remote control
Change "Remote Control Code" (-> 28) on the main unit and
the remote control (the two must match) if you place other
Panasonic products close together and it responds to this
remote control.
You can operate the TV or amplifier/receiver using the unit's
remote control.
1 For televisions
Input the code (-> 37) with the numbered
buttons while pressing [? TV POWER].
For amplifiers/receivers
Input the code (->37) with the numbered
[RECEIVER j VOL].
e.g., 0001: [0] -> [0] ->[0] -> [1]
2 Test by turning on the television or
adjusting the volume of the amplifier/
receiver.
Feb 20, 2016 | Panasonic Televison & Video
I got a replacement remote for the TV but it doesn't work on the TV. How do I get it to function with the TV
When you say "Replacement" you do not say if you bought an "Original type" replacement or one of those Universal ones which may or may not have the correct codes for the TV in question. Not all Universals have ALL POSSIBLE CODES.
You have two options.
1. Have your TV checked to find out if it is capable of responding to a remote control. If it won't then no remote whatsoever will make it respond ! Remote Receiving circuits fail as well !
2. If it is OK in that regard, get an original brand replacement Remote Control.
You can buy a Remote Control tester or you can take it to a TV technician who can check for you if the Remote is working.
Be sure to double check that you are using NEW batteries and that they are put into the remote with battery polarity as marked. You would be amazed how many times I have found that the problem was caused by persons putting batteries in the wrong way round !
Because of the shape of the ends of them, with some rechargeable batteries it is not so immediately obvious at to which is + and which is - unless you look very closely at the battery markings.
Jul 08, 2015 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Vizio vl370m remote control
If remotes have been ruled out the only way to test the remote infrared receiver is with the set apart/ and a schematic measure voltage at the receiver when the remote is used---most of the time since the part is rather small this is just replaced to see if it is or is not the problem; some receivers will fail where if the remote is held very close they work--always the receiver in that case.
Apr 12, 2012 | Vizio VL370M LCD TV
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
Remote will not work tv.
A working TV remote is a security blanket that allows us the peace of mind of knowing that we don't have to get up unless nature calls or the house catches on fire. People are more likely to spend more time and energy to fix their TV remote than to get up and change the channel. There are a number of simple fixes that can ease your mind when your TV remote is not working.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • New Batteries
  1. Check the batteries. Make sure the batteries are in correctly and, if they are, replace the batteries. If the batteries are dead or are not in correctly, your remote will not respond and the LED light will not illuminate when a button is pressed. Make sure the TV is plugged in. An unplugged TV will not respond to any remote.
  2. Check the selected input to make sure the remote is set on the TV and not some other device programmed into the remote, such as your DVD player, VCR, or video game console.
  3. Reprogram the sync code. If you are using a universal remote, it may have deprogrammed, leaving the remote and TV out of sync.
  4. Unplug the TV for a few minutes. During a power surge, a TV can become "confused." Unplugging it for a few minutes will give the TV the break it needs to sort everything out and work properly with your remote.
  5. Use another remote on the TV. Program a universal remote to work with the TV. If the TV does not respond, the problem is likely with the TV and not the remote control.
Jan 09, 2011 | Toshiba 62HM95 62" DLP HDTV
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
Can't turn off tv
Remote sensor problem.
Jul 12, 2009 | Directv RC23 Remote Control
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
TruTech PM1919BXA1 19 in. LCD TV Logo
50 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
