Question about Vacuums
How do I remove part C from part D ????? - Vacuums
  • 2,992 Answers
Owner's manual?
No Manual, try MFG website, or
manualslib.com
Posted on Mar 27, 2015
How to remove CLOG Riccar RAD.7 vacuum?
There is a clean out port on the back on the lower portion. Remove two screws to remove the cover to gain access to the air path from the floor to the bag. If this doesn't solve it you may have to remove the screws on the bottom which allow you to remove the cover of the nozzle assembly. There is a cover that goes from the floor to the direct air motor. Remove the screws to remove this cover which gains access to the air path and fan of the direct air motor. It's possible you may need to remove the direct air motor to clean out the fan if it has something stuck in there. This is not a job for the average person but if you are very mechanical you should be able to do it. If in doubt take it to your dealer. It is not very expensive to have done.
Apr 22, 2016 | Riccar Radiance Upright Vacuum Cleaner...
Remove hoover vacuum fan
I don't know what model you have but on most vacuums you need to remove the nozzle housing from the vacuum, remove the cover over the motor to gain access to the motor. Remove any screws holding the motor in. Remove the motor and take the screws out to allow access to the fan. Remove the fan, replace and put back together exactly as it was before.
Nov 09, 2015 | Hoover Vacuums
How to remove fan from rsl3c ?
Remove the bottom plate screws & bottom plate. Remove the screws holding the motor and fan assembly to the nozzle housing. Remove the screws Holding the fan housing to the motor to gain access to the fan. Remove the bolt holding the fan on the motor shaft to remove the fan.
Sep 08, 2014 | Riccar Vacuums
How to take hood of hoover u6437-900 vacuum cleaner
Hi! The hood on the cleaner shouldn't be removed. If you want to access the belt or the brush-roll the bottom place can be removed. To remove the bottom plate Disconnect cleaner from outlet. Use a Phillips screwdriver to remove the 5 screws on the bottom plate. Lift off bottom plate. Hope this was helpful!
Aug 01, 2014 | Hoover Vacuums
How do i disassemble my hoover f7220
Hi there! The tanks, brushes, nozzle and handle can be removed from the cleaner by following these quick steps below.
1. To remove the clean water tank simply grasp the handle and push down on handle to unlock it, then pull the tank out by the handle.
2. To remove the dirty water tank, slide the latches open located on the sides of the cleaner that hold the tank to the base of the cleaner. Grasp the handle and pull up and off.
3. For brush removal, with the handle in the upright position, tilt cleaner back until handle rests on floor. Grab brush assembly and pull firmly.
4. To remove the nozzle, with handle in upright position, tilt cleaner back until handle rests on floor. Pull tab at rear edge of nozzle and pull forward to remove nozzle.
5. For handle removal simply remove the handle screw and lift up on handle.
Disassembly beyond this point is not recommended. Hope this helps!
Jun 05, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
How to remove a clog
Hey there! Most of our vacuums you are able to remove the tool hose without the use of a screwdriver or other tools. Follow these brief steps to check your vacuum for clogs.
Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
Remove the hood or nozzle to access the brushes, remove the brushes. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose
Hope this helps you!
Jun 01, 2014 | Hoover Vacuums
Hoover self propelled U6630900 idler arm lock
Remove the bottom plate (4 screws), remove belts and brush roller. There may be 1 small screw in the center front of the vac under the brush roller. remove this one. If this is a bagless model you will also need to remove all of the back screws (torx) that hold the lower hose on. This needs to be removed to take the hood off. underneath on each side of the power drive assembly you will have 1 screw, remove them. there is a clip on each side that snaps the front on, push them out with a screwdriver. Then the hood is removed.
Feb 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do I remove the housing cover on a westinghouse vacuum?
Remove clear snap-in lights lens. Remove both lightbulbs. Where the bulb sockets are there is a screw, remove them. Then simply pull up on the housing from the rear where the wheels are and remove the top cover.
Dec 28, 2008 | Westinghouse WST1500 Wired Special Edition...
Removal of cloth bag on Hoover Concept One to wash
Remove the bag fill tube. If you look at the plastic holder it fits into, you will see two oval shaped recesses. Take a flat blade screwdriver and insert into the holes. Pry the driver by pulling gently towards the centre of the machine. This will release the clips that hold the plate on the unit. Once removed, also remove the two philips screws on the plastic plate on the bottom of the bag. This will allow you to remove the bag. If you want to wash it, be careful and do it by hand. These bags are no longer available.
Feb 23, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
