Question about Hudson Reed Signelle Designer Flat Panel Chrome Plated Towel Radiator Rail 59 inch x 19.5 inch
Towel radiator installed cannot get any heat
I think there is an airlock in radiator ,I have removed it and fitted an old radiator and it works perfectly
How do i get rid of a airlock in the radiator of 2005 Mazda drifter sle
Permanent air lock means your system has leak sum were or your reserve tank and radiator cup not function propebly full radiator fit cup Rev engine up to 1500to 2000 few times stop engine and top up sum time take 10 times.
Sep 11, 2012 | 2005 Mazda Drifter 2500
Kia carnival 1999 v 6 over heating already replaced radiator cap, water pump.thermostat
check radiator is not blocked, check air can pass through radiator (fins not blocked with debris) check that there is no airlock in system. is header tank being pressurised when engine running ( remove cap and start engine, look for bubbles in header tank). If bubbles then you need to check head gasket or even crack in head or cylinder walls. Presume you fitted the thermostat in the right way round. if you have boiled the engine since fitting the thermostat you will probably need to remove it (maybe see if it boils without it fitted) and possibly replace it again. (drop in hot water and see if it opens, if it doesn't then replace it)
Jun 19, 2012 | Kia Carnival Cars & Trucks
I have a 1990 Ford Ranger 2wd 4.0 liter V-6. I have replaced the water pump that went bad and the thermostat. Its still overheating very fast. I mean with in driving a few miles its already in the hot...
Check your temp sender in case its faulty, but if the enging feels that hot then its could be a number of things. Start with a possibly blocked radiator, or it could be a blown head gasket (is the water system getting pressurised? remove filler cap WHEN COLD and start engine, if it blows the water out or you see bubbles then its a gasket. It could also be that the system is just airlocked (having the header bottle (if fitted) higher than the engine when filling should maybe sort that, also check your heater pipes for bleed scews (fitted if airlocks are a problem on some cars) or maybe youve fitted the thermostat upside down, (check direction of flow). Personally I would go for either an airlocked system or a wrongly fitted thermostat.
Aug 20, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
When you shut off the engine the overflow jug bubbles,i've already replaceds the head gasket and it doesn't seem too be overheating and it doesn't do it when its running?
You could have an airlock still in the system. Run the vehicle at idle and squeeze the top and bottom radiator hoses with the expansion bottle cap removed. Add fluid gradually to it keeping it under the full marker. The bubbling is super hot air caused by air trapped either in the engine block, or top of radiator. A little tip while doing this, have the heaters on in the car and on high heat with the fans running at high speed. If you notice the engine getting warm and the heating in the car stays cold, the airlock is going to need a bit more work. Eventually if you have replaced the head gasket correctly the air lock with come out. Hope this helped...
Mar 06, 2011 | 1994 Nissan Altima
Heat blows cold air-no heat
first check to see if your heater hoses are getting warm you may just have a bad thermostat, if you've had any recent work done to the cooling system you may have an airlock which does not allow any coolant too flow through the heater core. do you smell antifeeze ?
Jan 25, 2010 | 1998 Ford Taurus
How do you fix an airlocked radiater. double radiater only one side heating up
its prob not airlocked but plugged , your going too have too turn off the supply and open a line on the downhill side , and drain it then open the supply line , and flush it out,!!!!
in other words disconect both lines from the raidiator, and flush it out till you get a steady flow of water on both sides!!!
Aug 31, 2009 | Plumbing
Overheating
Your overheating problems can have several possible causes.
1) Airlock in heating system - solution - bleed air from cooling system.
2) Radiator blocked - solution - drain and flush radiator
3) Failed waterpump - solution - fit new waterpump
4) Engine thermostat stuck in closed position - solution - fit new thermostat
5) Electric cooling fan (if fitted) failing to operate - solution - check fan, fan operating switch, all wiring and connectors
6) Not enough coolant in system - solution - check and top up to required level. Also check all hoses for sign of leakage.
7) Faulty temperature gauge giving incorrect reading.
Jun 21, 2009 | 2001 Jaguar XJ8
No heat
Should be located in a removable housing at the engine end of the upper radiator hose
Drain about 1 gallon of coolant from the radiator
Remove this housing
Note how thermostat is installed
Clean both surfaces
Replace thermostat and gasket
Re-install housing
Re-fill coolant slowly to prevent an airlock
Start engine and look for leaks
Run engine to normal operating temperature with heater on
Check coolant level
Mar 06, 2009 | 1993 Ford Probe
Corrosion to chrome towel radiator
your completely right mate about most conventional heating systems are open vented unless its a pressurised system..im a plumber and had at least 4 chrome towel rail rads that this has happened with,its a manufacures problem not yours,
send it back
Jan 15, 2009 | Home
Hudson Reed Signelle Designer Flat Panel Chrome Plated Towel Radiator Rail 59 inch x 19.5 inch Logo
476 people viewed this question
Top Hudson Reed Home Experts
john h
Tom Chichester
Are you a Hudson Reed Home Expert? Answer questions, earn points and help others
