Question about Panasonic KX-T7431 Corded Phone
How to display time instead of Ring Off? - Panasonic KX-T7431 Corded Phone
  • Bernadette Herman
    Bernadette Herman Mar 29, 2015
    Let me clarify. I want my phone by default to display the date/time. Right now it displays 'ring off' and the time. How do I change that so date and time displays? Thanks!
    New Friend:
  • 22 Answers
You can search for desired items by using the Jog Dial on the corresponding display menu. Rotate the Jog Dial in either direction as desired. The items will be displayed as follows. There will be seven displays.
Posted on Apr 02, 2015
I have 10 Panasonic KX-T7730 using 8 phone lines. I've confirmed with AT&T that all 8 lines are setup for caller ID. I've confirmed that all 8 extensions have the Caller ID enabled. Two of the
Firstly, you have not indicated which phone system your phones are connected to, e.g. KX-TA824, KX-TDA50 or other, so I'm a little in the dark. That being said, most of the Panasonic Systems only display Caller ID information (CID) to phones that are programmed to "Ring" on the line with the incoming call, and the line button flashes green to show it's ringing... so you must "system program" ringing for the line(s) on each phone. If the CID is not displayed on a particular phone, then that line is likely not programed to ring on that phone (it's light may flash red instead of green). After you "system program" the line to ring, you can still shut off the ringing sound on a phone using the slide switch on the left edge of the phone if you don't want to hear ringing, and this will not interfere with the CID display. Also, on a second note, CID does not display on the first ring coming in from the phone company (TELCO). The CID signal is sent from the TELCO to your system after the first ring has ended, during what would be the silence period that would occur before the second ring, if there was no CID. It is for that reason that most knowledgeable installers program lines with a five second delayed ring; in this way, you don't know the call has arrived until after enough time has passed for your system to receive the CID signal... this is why it seems the CID appears instantly, with an incoming call. Check out the line programming for each line and set it to ring with a 5 second delay. If you don't set up a delay, your phones will ring and if you answer the call immediately, its likely it won't allow the system to receive CID, so no CID will be displayed for that call.
Oct 28, 2014 | Panasonic KX-T7730 Corded Phone
Phones won't ring
All the phones should be connected to the same phoneline, for examble you can pick up the phone in the lower floor and at the sametime on the 2nd floor and you can yell at your staff for free. Without calling any numbers. Also they all should ring at the same time when connected to the same phone line.
I think you currently have the phones on difrent phonelines / numbers.
Also by haveing all the phones on the same phoneline only one call can be made at a time.
Instead of putting all the phones on the same phoneline you could take one phone, on the same phonenumber / line as your desk phone and take it to upstairs. thisway both phones will ring.
Feb 13, 2008 | Samsung Prostar 816 Phone
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
When compass is used the second hand points west instead of north
Are you wearing a ring on your finger that may be magnetic?
That could throw a compass off.
Jan 30, 2014 | Casio GA-1000-1ADR
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
Voice mail
Depending on the type and version of your partner system the procedure should be as follows:
1) from either ext 10 or 11 press the feature key and 00 on the dialpad
2) press the left hand intercom twice
the display should say system programming
3) dial "#506"
the display should say vms hunt delay
4) enter either 1 for day ringing assignment or 2 for night ring
5) dial the 2 digit line number i.e. line 1 is 01...
the display should say the ammount of rings previously programmed (3 Rings)
6) dial "2" on the dial pad
repeat the steps from number 3 on for the rest of the lines
7) press feature 00 whem finished
hope this helps.
Feb 03, 2009 | AT&T Lucent MLS-12D Phone
How to set alarm and ring with radio?
Hi gidgid.
This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
1. Press [ALARM] to switch to display the alarm setting.
2. Select ALARM 1 or ALARM 2 using [ALARM].
3. Press and hold [ALARM] for two seconds.
4. Use VOLUME [ + ] / [ - ] to enter the hours.
5. Press [ALARM].
6. Use VOLUME [ + ] / [ - ] to enter the minutes.
7. Press [ALARM].
8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
ALARM is selected, a two-minute crescendo alarm will be
emitted at the set time when the alarm is active. If RADIO is
chosen, the radio will be turned on for two hours at the set time
instead.
9. If RADIO is chosen, use [STATION] to choose the radio
station and press [AM / FM] to select AM or FM.
10. Press [ALARM].
11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
12. Press [ALARM] to exit.
Note: If there is no battery for the radio, there is no operation for
step 9 ~ 11.
sleepy head
Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
Ring back
If you call the extension internally, does it just ring no answer?
You will need to go into programming:
At extension 10 or 11:
Feature 00
Left interom twice.
#310
enter the extension you are having a problem with
pres the 1 button
the display will say 1-Assigned
Feature 00 to exit.
Jan 02, 2008 | Lucent PARTNER18 Corded Phone
Panasonic KX-T7431 Corded Phone Logo
75 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
