Question about Dryers
What is the part number for the heating elements for a Electralux eimed55iiwo heating element?
    Genius:
  • 1,167 Answers
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Troubleshoot Heating Element
Unplug the heating element. Take volt-ohm meter, set it to continuity and touch a lead to each unplugged wire on the element. If you get a reading (numbers indicating ohms) The element is good if it doesn't show continuity the element is burned out somewhere and needs replacing.
Oct 12, 2014 | Dryers
I have a water cooler with bottle on top and heater does not work for the hot water side
The model number is not a good number, but check the heating element make sure it is working, check the thermostat power to it and through it, if power through it but not going through it replace thermostat. if going through it to heating element and element not getting hot replace heating element.
Jul 11, 2014 | Whirlpool GI15NDXTSS
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
Lg dishwasher ldf6920st not heating/drying dishes What is the part number for heating unit or retro fit kit?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jul 27, 2011 | Dishwashers
The right front element will not heat properly on my Frigidaire electric stove. If you turn the knob to a low number it barely heats. It is very frustrating because you cannot keep something warm or cook...
Without a proper model number I would say you need to replace the element or the infinite switch for the element. Best off to call a reliable repair company such as Sears.
Jan 31, 2010 | Frigidaire Kitchen Ranges
My heating element isn't working on my kenmore dishwasher. Any suggestions? model # 13429
The # you gave is the catalog number. Please provide the model number, which is in the format abc.defghi . . . .
How do you know the heating element is not working? Could there be another problem causing the element not to operate?
Dec 18, 2009 | Kenmore Dishwashers
Maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | Maytag SDE4606A Electric Dryer
The dryer turns on but no heat is this the heating element or something else?
Most likely it is the element. The only way to be sure is to visually inspect it.
Aug 20, 2009 | Kenmore Dryers
DRYER HEATING ELEMENT
Kenmore dryers are manufactured by Whirlpool. In many cases the part numbers are identical between model numbers. Look at the dimensions of the heating element and compare part numbers. Chances are, the parts are identical.
Jun 29, 2009 | Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
