Question about Epson Stylus Pro 7880 InkJet Printer
Where can i get the Adjustment Program *free for Epson Stylus 7880 and Epson Stylus 7800
Both Printers are getting close to EOL of the Pump Cap Assy and i want to avoid an Maintenance Call 0040
SOURCE: maintenance request 0002
Epson
Maintenance request 0002What is this mean?
Posted on Jun 26, 2009
nyilasrobert
  • 627 Answers
SOURCE: Maintenance required 0040
Turn off printer
Hold PAPER SOURCE+PAPER FEED+CUT/EJECT buttons at the same time and keep them pressed
Turn on printer
Release buttons
Hidden new menu appears
press DOWN, “CLEAR COUNTERS” option should appear
press RIGHT
press UP, “MAINT TANK” should appear
press RIGHT
press ENTER (CUT/EJECT button)
Turn off printer.
Posted on Jul 17, 2009
  • 336 Answers
SOURCE: I need free drivers for Epson stylus dx4050
You free drive can be downloaded from http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cw77whFcRdwij2hyHj8VT41r0ltnWsi5bgU003D&tc=6.
Enjoy!
Regards,
Jeep Brainy
Posted on Sep 19, 2009
Testimonial: "I had been on this site looking for drivers my real problem had been not knowing how to download the drivers"
  • 3278 Answers
SOURCE: maintenance required 0040 code
Hello.
Your error code means the Pump/Cap/Cleaning assembly has reached the end of its life and will soon fail. This is a major replacement part and it is typically more cost effective to replace your printer rather than repair.
You can continue to print, but soon you will experience leaking ink, damaged hardware and poor prints.
Hope this helps.
Posted on Nov 14, 2009
SOURCE: EPSON STYLUS 4000 MAINTENANCE REQUIRED
While powering up the printer, hold down the three leftmost
arrow buttons:
[left-arrow] [down-arrow] [up-arrow]
You will get a whole different set of menus.
Use the up/down arrow buttons to select the "Clear Counters" menu, then press the [right-arrow] button.
Use the up/down arrows to get to the maintenance tank entry... where you can clear its counter.
Then turn the power off, wait, then turn it on.
You can use this diagnostic startup to clear most of the counters (and their related maintenance codes).
Posted on Mar 23, 2010
How to Reset Maintenance request 0040, Epson 9890
Did you replace the low ink cartridges? The 0040 request code is from the ink dispenser pump saying it has reached the specific number of pumps for that particular ink cartridge. Once you change out the low ink cartridge the pump will automatically reset.
Oct 15, 2016 | Epson Office Equipment & Supplies
Brother MFC J220 unable to print 73
The cap lift cam switch is defective. you will need to replace either maintenance unit or the ASF motor assy
Aug 17, 2014 | Brother MFC J220 Multifunction Printer
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Maintenance request code:
The pump counter is near end of life, replace the cleaner kit ASAP.
This is what 0040 means.
May 03, 2010 | Epson Stylus Pro 9800 InkJet Printer
Maintenance required 0040 code
Hello.
Hope this helps.
Nov 14, 2009 | Epson Stylus Pro 9600 InkJet Printer
My printer prints well, but with a displayed problem
This indicates that the Pump motor operation count has reached its limit. The remedy is to Perform Maintenance Mode 2 [CLEAR COUNTERS / CLEANER]
Sep 21, 2009 | Epson Stylus Pro 7600 InkJet Printer
REQ 0001002D
This is the result from running the machine with the maintenance code of 40 for too long (needs service parts replaced including pump cap assy and then reset counters). I have all you need (full maint manual, reset software and parts) if you need them. doadhe@gmail.com
Jul 04, 2009 | Epson Stylus Pro 7600 InkJet Printer
Epson 9600 print head missing numerous nozzels during test print procedure. Tried power clean several times. Do you have a remedy?
You willl probably need to clean the Pump Cap Assy.
You will need a strong flashlight/clip-on lamp to see what you are doing up in the area you are cleaning.
Move the print head to the left side of 9600. (If you need help with this let me know.)
Use a foam tipped swab slightly dampened with warm water to GENTLY wipe around the seal area of the Pump Cap Assy.
DO NOT USE A COTTON TIPPED SWAB !!!
Dip, Blot, & Wipe. Clean the Foam Swab often to wash off the residue it will pick up. Remenber to keep the swab slightly moist - not dripping wet.
If this does't help, it generally means that the Print Head is also very clogged with gummy/dried ink.
The Print Head cannot be cleaned without removing the Right Side Cover & then removing the Pump Cap Assy. This removing and cleaning is about a 1.5hr-2hr job for an experienced tech. Anyone with moderate mechanical skills can do it though.
Pump Cap Assy cleaning is usually done BEFORE replacing the Print Head.
If the Print Head cleaning doesn't work then a New Print Head is in order.
Hope this helps ! Good Luck !
Jun 10, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 7880 InkJet Printer Logo
165 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
