Question about Sewing Machines
What kind of thread do I need? - Sewing Machines
    Genius:
  • Sewing Machines Master
  • 1,181 Answers
For sewing what?
Posted on Mar 27, 2015
Needle not picking up bobbin thread
Install a brand new needle. Try a different kind of thread--AVOID old or bargain bin threads!
If that doesn't fix the problem, most likely the machine is out of time and needs to be serviced.
May 20, 2017 | Sewing Machines
The bobbin thread when sewing has little loops
You do not have the tension on your machine set correctly. That is leaving the bobbin thread too loose, hence the loops you are seeing. What kind of machine do you have? I can tell you where the tension is located. Also, tell me what kind of fabric you are trying to sew. FIRST JUST SET IT BACK TO THE FACTORY DEFAULT. When you are moving the machine it is easy to accidentally hit the tension and change it. Here is a picture of what a tension knob looks like. Good luck.
Apr 24, 2016 | Sewing Machines
Thread keeps bursting, tension is fine
Make sure you are using quality thread. Old, cheap or defective thread. Also, make sure the bobbin contains the same kind of thread.
Apr 18, 2014 | Sewing Machines
Melodie 40
I\'m not sure what you mean by "reel", but if you are referring to the spool pin which holds your thread, then you don\'t really have to have that. I use a spool stand instead. Then I can use any kind of thread without having to buy the little bitty spools. This is just an example of one style of thread holder. It is by far the cheapest way to replace a missing thread pin.
Amazon com Single Cone Thread Stand With Metal Base Thread Cone Rack
Some people also use a simple cup, and drop the thread inside, so that it doesn\'t unroll all over the work surface. Then thread the machine normally. If the thread needs to be directed to the first spot, a binder clip, attached to the handle of your machine, works really well as an extra "eye" to put the thread through, and secures it quite well.
Mar 10, 2014 | Singer 2662
Trying to quilt on my Hinterberg. First the thread kept breaking. Made some tension adjustments, now I am skipping stitches
possible problems
1) too thick for the feed dog to move the fabric forward need; lighter tension
2) are the upper and lower threads the same kind of thread?
3) is the thread feeding properly from above? sometimes the spool can snag the thread causing the tension to jump and skip stitches
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
My thread keep breaking no matter what kind of thread I use its something to do with the tension but nothing I do seems to fix it. I'm in the middle of a big Christmas project I need help fast I'll...
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Dec 21, 2012 | Sewing Machines
Thread nests
try changing the needle--make sure the needle is turned the right
way--and that the needle is the correct one for the fabric being
sewed--example--cotton fabric take one kind of needle and stretch
fabric take another kind of needle
try rethreading the machine top thread and bobbin
make sure to use every thread guide
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
if the bobbin and bobbin case have to be inserted togeather,,
make sure that the bobbin case is secure and snug in the machine
make sure the thread does not come off the thread take up lever
Nov 04, 2012 | Brother InnovIs 4000D Computerized Sewing...
How to thread machine
Go on www.youtube.com and enter thread a sewing machine. Or ehow for threading diagrams There are lots of free sites. You don't say what kind you have, that is like saying fix my car without saying what kind it is.
Feb 21, 2011 | Sewing Machines
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Nov 22, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
