Question about Plustek Opticfilm Office Equipment & Supplies
Grey and blue strips appearing when scanning slides
  • Clive Ward Mar 29, 2015
    The Grey and Blue strips are vertical. One third in from the left side. They are increasing with intensity on each slide pre-scan and final scan
    Scholar:
  • 98 Answers
This scanner does not work properly with Windows 7 and there is no fix yet that I know. Also, if you have another scanner installed, such as an all-in-one printer, it will cause conflicts. Having both Windows 7 and another scanner installed would cause this problem. Sorry it's not a fix, but without knowing your operating system (it takes a beefy computer to run) and your setup I can't be more specific.
Posted on Mar 29, 2015
I can't get the grey ribbon clip to lock into place
With some ribbon connectors, the ribbon simply slides into the connector until seated, there is no locking action.
Jan 26, 2014 | Tomtom GPS
Can I scan slides with Canoscan LiDE600F
Yep, The Canoscan LiDE600F is capable of scanning slides, however it is not possible to scan them in their mounts. If you dismount the slide, you can scan them using the film strip holder. This is not an elegant solution and you would have to remount your slides to use them as originally intended.
May 05, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
I am intstalling a new stereo into my mother inlwas 2005 hyundai accent. The problem I am running into is, after i accounted for the speaker wires, there are still 6 wires left: black, grey, blue, pink,...
Hello tinman3110,
Here's a link to ModifiedLife which shows the 2005 Hyundai Accent wiring chart. Some of the colors are duplicated, so for tapping and splicing, you will need to test to see which wire is which. For example, the chart shows "blue" for both external amp trigger and left rear speaker negative.
To avoid tapping into the car wiring, a better solution is to use a vehicle specific wiring harness. SonicElectronix sells the Scosche HYO3B which appears to fit the Hyundai Accent. Metra and others also make wiring harnesses and the Metra part number 70-7301 sold by www.installer.com appears to fit.
Hope this helps.
Jun 01, 2009 | Car Audio & Video
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
Color page in Batch to file
If you select color mode and scan grey and color pages, the output will be Grey for Grey abd color for color. If you had chosen to scan in grey mode, color will appear in Grey only.
There is an option to scan in both color and B&W simultaneously under multistream option.
S. Mohan, India
Jan 27, 2009 | Canon DR-9080C Path-Through Scanner
Wiring digram
left ashould be blue(+) blue w/black strip(-)right should be green(+) and green w black strip(-) thes are for front rear are left(purple(+) purple w/black strip(-) right gray(+) grey w/black strip(-)
Sep 01, 2008 | 1995 Nissan Pickup
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
54 people viewed this question
Top Plustek Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
john1959ny
john1959ny
Level 1 Expert
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
