Question about Onkyo Audio Players & Recorders
The RCA input jack on my onkyo powered subwoofer # skw 100 is broken, is there a part number for The RCA jack!
  • Onkyo USA Apr 17, 2015
    Please contact our Parts & Services Dept at the number listed below during normal business hours Monday-Friday 9am-5pm EST ; or via email at parts@us.onkyo.com. They can be contacted at 201-785-2600, option # 4 for Parts & Services as they can further assist you regarding Onkyo Parts and Accessories. You will need to speak with the Parts & Services department for any parts ordering/ shipping status, and availability or specifications for Onkyo parts and accessories.
  • Official Brand Answer
  • 333 Answers
Posted on Apr 17, 2015
  • 189 Answers
SOURCE: subwoofer conection
Ideally you want a speaker wire to RCA adapter like this one.
http://www.crutchfield.com/S-LaUCVO5Otro/App/Product/Item/Main.aspx?I=136CLR2SW
Posted on Jan 05, 2008
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
SOURCE: no signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Posted on May 14, 2008
proton77
  • 1183 Answers
SOURCE: broken connector in subwoofer connection on receiver
As per the user manual , the receiver has only one sub-woofer connector. The other alternative is to use the digital audio output for the speakers . That would mean either you have to change the speakers or get a conversion box that would connect your analog speakers to the digital output.
The other thing that can be done is to replace the sub-woofer connector. The same can be done by a radio repair guy or you can take it an authorised pioneer repair centre.
Thanks
proton
source:http://hometheater.about.com/od/avreceiversreviews/gr/piovsx91txhs.htm
Posted on Jul 27, 2008
  • 14 Answers
SOURCE: Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Posted on Mar 05, 2009
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
How do I connect a Yamaha sws100subwoofer to onkyo home theater receiver
Use a subwoofer cable from the back of the Onkyo (it's labeled "SUBWOOFER OUT") to the subwoofers Input jack. It's an RCA style connector and can be bought at any electronics store or online.
Feb 16, 2015 | Yamaha Audio Players & Recorders
Onkyo sub will not power up?
does the green light power up on the back? If not the power supply is bad
Aug 25, 2011 | Onkyo SKW-200 Subwoofer
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
My onkyo subwoofer does not turn on the green ligth is not on, what could it be? is a swk-200
My Onkyo S/W did the same thing untill I unplugged it from the surge protector that all the other A/V devices are plugged into. I plugged the sub into it's very own wall recepticle with it's very own new surge protector. Maybe cleaner power is the answer.
I have an Onkyo SKW-50 subwoofer and when I turn on the power to the subwoofer, it is making a low-level humming sound. When I turn the frequency dial up or down, the sound of the hum gets louder or softer...
may be u have a power problem check if ur ground is well connected to ur amplifer and also check the input cables if there ground wires r intact and make good contact
Dec 20, 2009 | Audio Players & Recorders
Feb 16, 2009 | Onkyo HTR500 Receiver
Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Onkyo sks-ht540 subwoofer
Sounds like power problem of some sort ,have you read the instructions properly.some of these will have on/off switches in the wierdest of places
May 25, 2007 | Onkyo SKW-200 Subwoofer
107 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
