Question about Dryers
How do I reset a Beko dcu9330w tumble dryer?
It's not heating and I have cleaned everything thoroughly.
  • Dryers Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Posted on May 04, 2015
futureloginn
  • 734 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
  • 2920 Answers
SOURCE: My tumble dryer is spinning but no heat.
it sounds like either your heating element went out or your limit switches are bad
Posted on Jan 14, 2009
  • 691 Answers
SOURCE: i have a beko DRCS68W tumble dryer but its not
you have to call service centre if under warranty or you'll invalidate it if you have a go. it will be the element or a heat sensor/switch most likely.
Posted on Jan 16, 2010
SOURCE: how do i change my tumble dryer belt on a beko
Just changed the belt on a Beko DRCS68W and its a real pig! Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spline on to the back panel. You will also need to disconnect wires/leads on top right inside panel to give you more space. Once you have done this you should be able to ease away the back panel far enough to get the new belt around the drum and over the drum spline in the middle. Then the tricky bit - getting the belt tensioned on to the motor drive spline. I did this before securing the drum and back panel, which gives a bit more flexibility. I also used about 15ins of 15mm copper pipe to ease the belt down over the motor spline. Hard part was getting the back panel back lined up with the screw holes as the belt tension distorts the casing. Finally hit on the idea of lying the machine on its side so the weight of the drum is pulling away from the motor and helping to line up the screw holes. Two and a half hours later job done! I guess if I ever did another it would be a whole lot easier but still not the type of job I relish!
Posted on Jan 18, 2010
  • 45 Answers
SOURCE: i have a beko tumble dryer drc68w it's spinning
It is the heating element easy to replace.
Posted on Apr 28, 2010
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    My beko dcu9330w tumble dryer has stopped spinning... Any idea?
    Probably a belt broken or slipped off. Does it still whir, as if the motor is running, but the drum does not move? If it does, then you can be certain it is a belt problem. Fairly cheap from your local spares supplier.
    Mar 08, 2015 | Dryers
    Beko dcu9330w. Why isn't it heating?
    if everything else is working and spinning the drum
    door safety switch works
    faulty heater element is the most common cause
    that one does have an electronic control panel and timer
    might get that checked over at the same tine
    Jan 28, 2014 | Dryers
    My beko tumble dryer is not heating up
    Elements is generally behind the back panel, may not be an element fault but a tripped stat. If you're lucky the stat will be a self resetting one and not have to be replaced just reset. Always isolate from mains before removing any covers etc.
    Apr 12, 2013 | Bosch Neff Beko Dryer 263297
    My beko drcs 76b tumble dryer isnt heating up
    First turn of the breaker, then back on. Check the wiring from the plug at the receptacle to the back if the dryer. You should find your problem there. Then next is the element. See if the wiring is ok to the element. Next visually check the element for
    Mar 10, 2013 | Dryers
    Dryer has no heat, everything else works fine.
    clean out the lint from the exhaust vents thoroughly and try again
    Aug 22, 2010 | Kenmore Dryers
    Dryer seems to take longer to dry things.
    Remove the exhaust vents tubing and clean out thoroughly good. Any lint build up will make the moister sensor to keep the heat in check. If cleaned and still does not heat very well replace that sensor. If no heat is present replace the spark ignitor instead
    Jun 19, 2010 | Dryers
    G.E. gas dryer will not heat.
    either the moister sensor is bad or the venting needs to be cleaned thoroughly. If clogged full of lint the sensor shuts down the heat until it is cleaned out
    May 13, 2010 | Dryers
    Dryers Logo
    401 people viewed this question
    Top Dryers Experts
