Question about Hunter Dryers
My Hunter fan will not go in reverse and there is no such button on the remote # 27185-560, anyone know what to do?
    New Friend:
Try this. To change fan from counterclockwise to clockwise get the fan going on high. Hold the hi button while switching the wall switch from ON to OFF to ON quickly the fan and will switch direction. To go from clockwise to counterclockwise just hold down the low speed button on the remote until it switches direction. Hope this helps. It only took us seven years to figure it out.
Posted on Apr 11, 2015
    Genius:
  • Hunter Master
  • 1,617 Answers
Look on the switchcup where the pull chain for the fan is at.
Posted on Apr 08, 2015
  • 78 Answers
There should be a reversing switch located on the housing
Posted on Mar 27, 2015
jyackle5
  • 8197 Answers
SOURCE: My fan reversed, but my controller does not have a reverse button
There is a switch on the housing of the fan. It is under the blades and above the lites if you have lights. Also same area as the chains. That is the reverse switch you might have hit it when cleaning the fan. just flip the switch iy goes left to right or reverse.
Good Luck and please rate
Posted on Jan 23, 2009
SOURCE: hunter ceiling fan with remote will not reverse.
I was puzzled too... here's my fix... the remote has six buttons, the very small one at the top is the reversing button. Remote is part # 85095. It's a Westside II fan, bought at Costco.
Posted on Jul 03, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter Fan problem
Thge black boxes are capacitors. One is a single and the other is a dual. Evidently the dual runs the two lower speeds and the single run the high speed.
You can test capacitors for basic operation with an analog voltmeter set to Ohms (Rx1 setting is best) by charging up the capacitor with the leadshooked up in one direction, and then reversing them to watch for the slight jump as the capacitor discharges back into the meter... note that this test only works with an analog meter and it must be set to ohms.
This is only a basic test for capacitors and will not indicate if it's withing specs, only that it basically works.
IMO, Hunter is known for having bad capacitors. I've just purchased two fans and already had to swap out the light kits, which contains the capacitors and switches, in one becuse of poor operation and excessive humming noise. since the other fans has the same componenets, other than being a different color, I also thought to try the light kit/capacitor assembly in the fan I've already installed before also installing the second fan.
Guess what, the other set of electircal components with the capacitors runs the fan slower and hums louder.
According to Hunter's web site, humming is a sign of poor engineering in ceiling fans (meaning a power hum rather than a hum from loose components) I agree and Lowes is about to get two Hunter fans back as my three cheapo fans that came with my house do not hum and also the one in my old house did not hum and moved more air.
Even the better capacitor set that I switched out still hums to some degree, so I'm climing Hunter's using **** components, probably becuse their chinese suppliers are screwing them and they're not bothering to keep up the quality control.
Posted on Jun 08, 2010
SOURCE: Hunter Fan Remote Control Part No. 85095-01:
My Hunter Remote does not have a Reverse button and can't find the manual
Posted on Jun 11, 2010
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Rhine uc7067
You probably have to do the reverse manually as you have a Hunter remote on a Emerson. Why do you want it to go in reverse?
Jul 18, 2014 | Emerson Fans Dryers
Reverse hunter mission fan
need to know how to programme carib 880e remote
Jul 23, 2013 | Hunter 54"" 1912 Mission 5 Blade Ceiling...
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan with remote will not reverse.
Jun 16, 2009 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
361 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
