Question about Sharp LC60E69U 60 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 120Hz, 4
I recently replaced the main board on my sharp tv and now the remote doesn't work. Is this something that needs to be reprogrammed or is the main board faulty?
    Top Expert:
  • Sharp Master
  • 74,383 Answers
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 28, 2015
  • 96 Answers
Hello. You should re-check the connections to make sure nothing is loose or not lined up, and check if any wires got pinched from not being routed correctly.. If all connections are okay then the Main board is likely bad.
Sharp aquos tv won't turn on with remote, replaced ir board, still not working
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Mar 18, 2016 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
Remote control select buttons not working
First replace the batteries in the transmitter. If that doesn't work you may need either the transmitter, or the IR PCB & possibly the MAIN PCB(this is the IR board & MAIN inside the TV for which you will need the TV model#)
See the following website for transmitter :
http://www.amazon.com/s/?ie=UTF8&keywords=sharp+gb004wjsa&tag=googhydr-20&index=aps&hvadid=27053766363&hvpos=1t1&hvexid=&hvnetw=s&hvrand=13949172362774600291&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_40f8n9hcep_b
Mar 04, 2015 | Sharp Aquos Televison & Video
Remote not responding
look at this video
you need to shoot a video or take an image using your cellphone
the ccd sensor is sensitive to the transmitter IR Led at the Remote
and can show you whether it emittes photons and works
Apr 16, 2014 | LG 50PS80 50 in. HDTV Plasma TV
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
SHARP LCDTV GA667WJSA Remote Locked, What can I do to get it to work?
I just received a replacement remote for my Sharp LCD- GA667WJSA. Doesn't work. Shoud it work immediately or is there something I have to do first?
Oct 07, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Re-program a Sharp remote control for LC-46XD1E
Are you sure it is the remote that has stopped working? If you get something like a camera phone and put it over the LED on the remote and press the buttons (with the phone in camera mode) the camera will pick up the infered signal from the remote. This will rule out if it is the TV or remote.
If you get the infered signal then your TV is faulty (possibly a main pcb fault) if you dont then it is your remote. Which as far as I am award you can not reprogram, but you can get them from places on the internet (search on google) for a couple of 10 pound.
Jan 30, 2010 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
Sharp LC60E69U 60 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 120Hz, 4 Logo
43 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
