I am getting either error code E1 or its EL on my front loader washer, wanting to know what this means?
  • Washing Mach... Master
  • 2,992 Answers
Owner's manual, no manual, MFG web site.
No luck, try manualslib.com Make, model, possibly year and serial number. You will want to have it next time.
Posted on Mar 27, 2015
  • 14,573 Answers
    Top Expert:
  • 51,482 Answers
Call a service man .
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
Washer fills and empties but doesn't agitate. Error code of 1.
Would need to know the make and model!
Sounds like the clutch may have gone if it is a top loader or the belt if a front loader.
Aug 16, 2015 | Washing Machines
I have a Electrolux front loader and im getting an error code of e35 what does this mean
Signals washer has overfilled, pressure hose or pressure switch most likely
Dec 25, 2014 | Electrolux Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have an E1 message on my samsung front loader, can you tell me what that means?
Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
E1 in Samsung Front Loaders: It means the machine has detected an error in inlet water filter or the water pressure. Some of my sources indicate E1 could also be a leakage error It could all mean a faulty sensor but you should check th water lines, the door seals and the floor beneath the machine for tell-tale signs of a leaking system. Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
If you can fill the washer, but it faults with and E1, and can go no further, my research shows a common cause for the problem is the PVC tube connecting the pressure sensor to the drum has experienced a problem. In some modern washers, the water level is measured and regulated with a pressure sensor connected to the tub with a plastic tube. As the water level rises inside the drum, the pressure rises inside the sealed tube. The tube can sometimes become detached or even plugged with lint, soap or wash grime. Check the pressure sensor line to make sure it is attached to the drum and is completely unobstructed by foreign objects or deposits. If so, clean the debris and/or reattach the tube to the drum and try running starting a cycle. If you don't get the E1 code - Hooray, everyone has clean clothes again :-)
If this does not work, here is a link to a Washing Machine User Blog which might be able to offer more experts and more specific information http://www.applianceblog.com/mainforums/washers
Hope this answers your questions and helps FixYa! If you found my information useful and informative, won't you please show some love and rate this solution or better yet, send us a brief testimonial on how our free support made your day and averted disaster.
Thank you for choosing FixYa.com.
Colt Baldwin - FixYa.com Guru
Mar 26, 2011 | GE WBVH6240F Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Error Code E1
Usually when the thermistor is repaired the high limit is replaced, I dont recall the E 2 except a manual is under the console
Jun 01, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
