Question about Health & Beauty
Have not used it for awhile - new batteries numbers showing only half on screen
  • 2,963 Answers
Double check the position of the batteries. Usually, the batteries are opposite + end next to each other. I presume the screen was ok before with the old batteries?
Posted on Mar 27, 2015
Testimonial: "New Batteries are in correct - it might be in the screen for not using it for 2 years."
Sanyo model number DP46849 half the screen is black
This is a problem with the ribbon cables taking the signal to the various parts of the panel. The cable is bonded at the factory. That bonding has failed in one part of the screen.
Unfortunately, the bonding can't be fixed with just a blob of glue. If the ribbon cable is removed then it will never work again. The connections are too fine.
The answer is to use some neoprene tubing to put light pressure on the connection. This is done by opening the case and inserting the neoprene like a round wedge.
Sep 08, 2014 | Televison & Video
My sony Bravia kdl-46v5500 screen has colored lines on the left side then half the screen flicks black then the same left half side of the screen stays black then will go back to normal and then go...
These sets use for the most part two boards--each drives the screen on one side---also possible as suggested here the problem is inside the panel or where it connects to these boards--if inside the panel (the entire front screen unit) it is fatal as it cannot be got at and the display costs more than the set did new.
Oct 29, 2012 | Sony BRAVIA KDL46V5500 46 in TV
After awhile my t.v. has been on, half the screen will go black. How do i fix this??
May I know what portion on the screen turned to black, is it top half, bottom half, left/right side. Also please confirm if your TV's model no. is 50PQ30C, it is printed at the rear panel, manual, and receipt.
Dec 15, 2011 | LG 50PQ30C 50 in. Plasma TV
J.hughesneed to know when battery is full shows a white battery is that the color when full or is it still not charged
batterys usually show half colour when not full.
watch the battery indicator from time to time with mains power disconnected to see change
usually when charging the the indictor will flash.
run mouse over indictor if on screen and it should tell you how much % of battery is still left.
not possible to be more specific without model number
I hope this was useful.
Jan 11, 2011 | Computers & Internet
My screen on the lg vx5500 cell phone is making strange shapes. When the phone starts up, the bottom half of the screen shows what should be on the top, and the top half is just a white screen. When I...
Your problem is caused by the communication foil between the LCD and the mainboard of the phone. This foil contains a number of circuits that makes data transfer possible. The one or more circuits do not communicate anymore, the phone displays odd images.
Nov 07, 2010 | LG VX5500 Cell Phone
Image set up of screen is only half of the monitor
If you v-size is already at 100% then the issue is with the picture being sent to the monitor. Based upon what kind of input you have for the monitor there is a number of different ways to fix this. I will assume you are using the monitor with a desktop computer. If this is for XP, then there is a simple fix as follows, adjusting your display properties:
Right-click on your desktop background and then click on "Properties" this will open up a new window. Select the "Settings" tab, then drag the green arrow in the "Screen Resolution" field to the desired setting. Since you have a "widescreen set-up" you more than likely have a resolution where the first number is about twice the second number...they should be close to even to have a square image (bigger numbers show more detail than smaller numbers).
Hope this helps!
Jul 16, 2010 | AOC 7F 17" CRT Monitor
Engine sounded noisy & scratchy when i drove to school oil light on. Got back to car after 10 mins everything came on (radio etc) but when i went to turn it over everything just cut out like dead...
after the vehicle cooled completely and all the oil drained down it showed half full? that would mean it was anywhere from 2 to 2.5 quarts low? unless you mean that it showed halfway up the full / safe area on the dipstick.
the oil light being on usually means low oil or low oil pressure, if the vehicle still doesn't try to start after it is completely cool then you might have a locked up engine or multiple problems, check the oil again now that it has been sitting awhile look for water in the oil also check for oil in the water.
check battery connections again, make sure they are tight, if lights and such work then try to get a jump from someone. even new batteries can go bad
I would definitely be worried about that oil light though.
good luck and I hope this helps.
Feb 22, 2010 | Toyota Previa Cars & Trucks
Battery Charge
Get another battery and try charging it. You should have a second, backup battery anyway. That should narrow it down between the charger and the battery as to which is defective. How old is the camera? It may be a better investment to put the money into a new camera. Also, look on EBay for a new charger if you find that it is the problem. There are many third-party manufacturers of chargers and batteries that work fine and cost much less.
Jan 23, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Multiple problems
Does it do the same thing in safe mode?
Nov 29, 2007 | HP Pavilion zd8000 Notebook
Health & Beauty Logo
88 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
