Question about Garden
Why does the engine sometimes, stall when i engage the mower blade?
    Top Expert:
  • 10,875 Answers
The spindles are bound up,make sure the blades spin freely,take key out and turn by hand,clean under mower,replace spindle that is bound up.
Posted on Mar 27, 2015
When I push up lever to engage the lawn mower blades it will not engage them and will stall the engine
If the operator seat saftey switch is defective the engine will stall.
safety-seat-micro-switch-fits-husqvarna-lr100-lt100-lt130-ayp-craftsman-rally-jonsered-mowers-532121305-121305-450-p-soavr15tiwcrglcekobpw2on-2-5.jpg Hope this helps?
Jun 23, 2017 | Garden
I have a Husqvarna GT54LS riding mower with a B&S engine. It starts and runs well. When I engage either the mower deck or the differential lock, the engine stalls. What can be the problem?
occupant switch on seat thinks there's no operator in seat with blades engaged , so safety ckt shuts engine off
seat switches go bad sometimes
Sep 14, 2016 | Husqvarna Garden
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Engine stalls
could be a stuck pulley or bearing, or debris in the cutting deck. make sure the blades turn freely with mower off and blades dissengaged. If they dont, remove the deck and check all of the pulleys for freeness.
Jun 02, 2014 | Craftsman Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
14sb engine running when blade clutch is engaged the lawnmower stalls.
Normally I believe this mower to have a Kawasaki engine, and the main jet and 'pilot air hole' need to be cleaned. You are running a lean condition, and when the blade is engaged, the engine does not have enough fuel to continue the extra load. A small test for this is to engage the blade and the choke at the same time. If the engine has enough fuel to continue running and engage the blade, this confirms the lean fuel condition. Cleaning those jets will solve the issue.
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Aug 08, 2009 | Garden
Mower wants to stall when blades are engaged on a Huskee 13hp 38'' cut Tecumseh engine 6 speed on the go shift
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Jun 23, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
