Question about Keurig Elite B40 Coffee Maker
It keeps cutting off, have to keep hitting power button after on for awhile
    Problem Solver:
  • 39 Answers
Inside the coffee maker there is a small screen filter that must be be half plugged you have to take the machine apart to clean it, it is hard enough job to fix it.
Posted on Mar 27, 2015
Why does my sharp tv keeps cutting off after 3 hours?
It is a power saving setting. You likely accidentally pressed the power saving button on your remote. Try locating said button and pressing it again.
Or try something like this:
1: Press MENU to display the MENU screen, and then press c / d to select "Power Control".
2: Press a / b to select a speci?c adjustment item, and then press ENTER.
3: Press a / b (or c / d ) to select the desired setting, and then press ENTER.
4: Press MENU to exit.
Sep 29, 2015 | Sharp Televison & Video
Why will my 2001 ford ranger not start after cutting the why will my 2001 ford ranger not start after turning the truck very hard to keep from hitting another car, / why will my 2001 ford range...
SOUNDS LIKE YOUR FUEL CUT OFF SWIYCH POPED . IT IS A BLACK SWITCH RED BUTTON ON TOP PUSH DOWN RED BUTTON TRY TO START AGAIN LOCATED IN KICK PANEL PASSENGER SIDE.
Feb 15, 2015 | 2001 Ford Ranger - XLT, 2WD - Speed Grille
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Ninja Blender 1100 starts then stops almost immediately, is there a way to fix this?
It Could Be a Number of Things..
It's most likely that the electrical Wire Could Have a Shortage, If it cuts off again Try gently Wiggling the Electrical Wire in a Number of Directions If it cuts on and off while your fidgeting with it, you've found your Problem! A quick fix would be to Adjust the wire In the position it would cut on the strongest, wrap the cord with Tape to Keep the wire in that Position, this will Prevent it from shorting again.
Either that or you simply put too much product in the Blender with an inadequate amount of liquid.
Jan 04, 2014 | Blenders
My at&t pantech burst keeps restarting. how can i get it to turn on and not restart?
You have to reset your whole phone. Hold the power button and the volume button down at the same time until Pantech pops up on the screen and when it does let go of the power button but keep holding the down volume button down. When the triangle pops up let go of the volume button and press the menu button. Use the volume button to scroll down to wipe data. Hit the home key.. scroll down again to yes and hit the home key. Hit the home key again on reboot system. That's it ! :)
Oct 20, 2012 | Cell Phones
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
RCA RCR311B Remote Control
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie TV) while holding TV press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Oct 26, 2008 | RCA 3-Device Universal Remote
My TV won't turn on...
check the power supply sounds like its going out
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Keurig Elite B40 Coffee Maker Logo
127 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
