Question about AO Smith Miller / LSI / Home / Nordyne Replacement Furnace Motor 1/5hp 1050 RPM 115 volts OML64
Miller Plasma not cutting properly keeps ruining tips
We have the 625 it works real good for about 2 feet of cutting and then its spits out green flame and melts tip and starts cutting ugly line
  • 6 Answers
It may be an air pressure problem. Plasma cutters require a constant flow of air at a certain pressure to work properly. If the compressor can't keep up and the pressure drops it can create problems. Have someone watch the pressure gauge while you're cutting to see if the pressure remains steady. You may need to adjust the compressor pressure switch or you may need a larger compressor.
Hope this helps.
Bob
Posted on Apr 02, 2015
Miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Green light flashes
always remember the ground...
have a big air supply. small compressors can not keep up and machine stops cutting.
Nov 24, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
I have a Miller Spectrum 625. The problem I am having is that after cutting for three seconds the torch quits cutting. Have had it looked at a Miller repair center. They said they cut with it for over...
Hi:
I found similar problem with few customers and one issue (should I said the standard issue) is the source of air. You need a steady pressure and flow of air into the machine. Check your air compressor you will need at least 6 cubic feet per minute (360 cubic feet per hour) and a 90 psi of pressure. Since there is no way to check the flow (unless you have an online flow meter at you air pipe) check the pressure at your air tank (reservoir), if the pressure drops below the 70 PSI then that's the problem; your compressor can't stand the flow. Other than that check your ground clamp and make sure it's making a good contact.
Good Luck.
Sep 15, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
When you start cutting it will cut about 2 inches and kick out you let off the trigger and pull it back on it will do the same as long as you do that it will not cut continusle please advise does not...
You may need a better air supply. Also check the tip. This sometimes happens with mine when the tip gets pitted, not sure why but changing the tip sorts it out. They are fussy machines in some ways. Dont like dirty material, need a good earth.
Aug 31, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller plasma cutter not cutting
Hi:
Miller plasma are pretty realiable. Without more details; what you need to do is check the contact tip and the electrode if these ones are won, replace them. If still doesn't work; check your air pressure; main source must give you at leats 90 psi and 9 SCFM of flow,
Good Luck
Mar 12, 2011 | Miller Welding Tools
I can cut for about 4 min. then Cup Error
look at your duty cycle 40 % duty cycle is 4 min 10 min sraight is minimum 100%, but good machines weld for 3 or 4 shifts till they get turned off
my 2 cents
Feb 25, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I bought a used miller spectrum 625, can put on
The consumables on the torch head could be incorrect or not installed correctly. check these.
Sep 28, 2009 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Hobart 250 a keeps cutting off the flame
If you have a bad air supply then the moisture in the air will cause the torch to cut off and the cut quality depends also on air supply,speed,metal thickness and condition of your consumables,meaning your electrode and other related parts in the torch tip.Hope this helps
Jan 05, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
AO Smith Miller / LSI / Home / Nordyne Replacement Furnace Motor 1/5hp 1050 RPM 115 volts OML64 Logo
172 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
