Question about Frigidaire Stove/Oven/Range Cooktop - 318079348
How can I purchase replacement knobs for model # SKGA20AMBJG purchased in Costa Rica?
This is a small 4 burner stove purchased 2 yrs ago & someone stole 2 knobs off it
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Look the number up on sears the ebay it
Posted on Apr 13, 2015
2 Suggested Answers
  • 3 Answers
SOURCE: How do I clean the burners on a stove
You can take them off and hand wash them
Posted on May 06, 2012
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Should I buy a two burner unit if available? Or a new cooktop?
Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
Dec 29, 2009 | Cooktops
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 | Cooktops
(2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
Frigidaire Stove/Oven/Range Cooktop - 318079348 Logo
188 people viewed this question
Top Frigidaire Cooktops Experts
Oloyede Monsuru
ray gallant
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
