Question about Garden
I want to change oil filters and oil in a zero turn lawn mower and the top port plug needs to be removed for refilling.The plug has never been removed and I can't move it without doing damage to the transmission. Can I refill this transmission completely thru the reservoir tank without removing the top port plug?
  • 5 Answers
SOURCE: Refilling transmission fluid - manual 5-speed.
dextron mercron 3, automatic transmission fluid. Mostly standard on fords and others for both auto and manual trans. Underneath the air intake pipe, at the rear right hand side there is a 4 prong plug for the speed sensor. Its electronic so there wont be any cable, its a round sensor with a horizontal plug on the end of it. Take a flat head screwdriver and pry the 2 holding prongs off the wiring harnes. then get a #10 socket 1/4in drive with exstinsions works best take out the bolt going right with the rachet. once you get it out just pull and twist the sensor out. It seems to be easier with a hose at the end of the funnel to pour the fluid in. stick the hose where the speed sensor was. once its full just assemble it back the way it was.
Posted on Oct 17, 2008
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 109 Answers
SOURCE: weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Posted on Apr 16, 2009
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
rburroak
  • 14 Answers
SOURCE: MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Posted on Jun 19, 2009
Left hand drive handle hard to move forward
drain and replace your hydraulic steering system oil and replace the hydraulic filter then refill system
Jan 26, 2016 | Toro TimeCutter Zero Turn Lawn Mower...
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
Why is my troy-bilt mustang 50 zero turn lawn tractor is smoking and burning oil?
it could need a oil change if it as some age to it could need a new ring set or a new overhaul and it my need a new plug ...
Aug 04, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Trouble starting and a lot of black smoke at startup
Could be. Black smoke means too muck fuel or not burning properly. Also make sure your oil is not over full.
Apr 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
When engaging the deck mower the motor slows, rather than regaining RPMs as the throttle is increased to max (Rabbit). The mower actually slows even more in thicker grass and occasionally stalls. ...
have you removed the sediment bowl located on the bottom of the carburetor and looked to see if there is a lot of dirt and gunk in the bowl,then while this bowl is off there will be a float (metal or plastic) make sure theres a good supply of gas running out of here where the bowl would normally be,if not,then it could be a plugged needle seat or port in your carb and will need to be cleaned
Apr 14, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
