Question about Kipor Electrical Supplies
What to check when the Kipor 4,5kw generator slows down once you connect some things like iron?
From a couple of days my gen reacts badly when I connect the iron or the wash machine (at the moment of warming the water up). The engine is slowing down up to stop and the there is a lot of smoke coming out from the gen. WHen I run the engine it comes to the proper speed quite slowly. The voltage on the output is ok but I think there is a problem with the frequency, I tried to control it with the multimeter, it seems to be about 200hz. I have no oscilloscope to control the characteristic of the output. can you help me?
  • 169 Answers
SOURCE: coleman 1850 sport, no/ low generator output
The engine should run at 3750 rpm at no load. If that's OK then you may need to troubleshoot the capacitor inside the end of the generator opposite the rope. Since the thing has been stored for some time you may just need to flash the field of the generator to restore the residual magnetism in the rotor. The easiest way to do this is thru the 110 outlet but it's a little dangerous. Plug an old lamp cord into the outlet, start the generator, and momentarily connect a 9 volt dry cell to the wires, then shut the generator down and see if there is 110 when you restart it.
Posted on Feb 23, 2009
  • 169 Answers
SOURCE: coleman 1850 no/low generator output
Both the Hz and the voltage will be wrong if the engine speed is low. You need to use either a DMM with a HZ function to set the engine speed so that you get 61.5 Hz at no load, or use a tachometer to set the no load speed to 3750 rpm.
Posted on Mar 01, 2009
  • 98 Answers
SOURCE: ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
Posted on Oct 11, 2009
  • 342 Answers
SOURCE: Generator CAT3306 - 180kVA - 380V output...when
soud like an engine management fault
or a more complex avr does it have an electronc govenor
Posted on Apr 04, 2010
  • 5603 Answers
SOURCE: black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
Posted on May 02, 2010
Testimonial: "Still working on the problem but tips were a real help."
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
I have a Wacker portable Gen gs 5.6 It runs good but it also don't put out power ether
I suspect the inverter module has failed. The module failed on my kipor gen and produced the same problem, ie no A/C outpu. Module was about $300 for Kipor. Fitted myself, problem solved.
Dec 06, 2014 | Electrical Supplies
Just purchased kipor 770 gen what total watts can i use at one time?
That should be specified either directly on the generator or in accompanying information.
Oct 19, 2014 | Electrical Supplies
I have i a kipor 11 kw genset. My home voltage is a 220v phase and neutral. When i start the genset, it trips the RCD, Solution ?
first start gen with no connections. when it trips then already fault is in gen wires when its ok, try with dril, hairdryer or whatever. when ok try to connect to your home installation, make sure power of electricity company is complete off.
Feb 04, 2010 | Briggs & Stratton Power Products 5,550...
Kipor kde6700 starts but doesn't produce electricity
check your owner manuel for how to excite the gen set. check breakers and see if this one has a fuss.
Oct 13, 2009 | Kipor Parallel Wiring Kit, 30 amp Twist...
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Apr 05, 2009 | Watts Onan Portable Generator - 4000 ,...
Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
Now for Sears to try to locate the tool that will open the case.
Apr 17, 2008 | Euro-Pro Steam Generator EP8001 Iron
Electrical Supplies Logo
41 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
Level 1 Expert
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
