Question about Miele S8 Cat and Dog S8380 with Free Hepa Filter
Bag full. changed. will not stay powered up. where is the reset button ?
    Top Expert:
  • Miele Master
  • 10,875 Answers
Posted on Mar 27, 2015
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
Jun 02, 2014 | LG Dehumidifiers
Full light is on and won't turn off
There is a float in the back, make sure it is dropping all the way. If the rear tank isn't fully inserted it will also prevent the full indicator from resetting. Occasionally hard water deposits will build up, and it's usually just a matter of cycling the float up and down by hand a few times till it loosens up.
Apr 24, 2014 | Kenmore 54501 Dehumidifier
Full light stays on always
Don't know your model specifically, but most dehumidifiers have a float that shuts the system down when the tank is full. Maybe the float is not going up and down like it should. With the power off and the tank out, see if the float is descending like it should when the tank is out. Popping it up and down a few times might solve the problem.
Apr 13, 2014 | Comfort-Aire Dehumidifiers
Display says full
Check to see if there is a "reset button" and reset it. Try to unplug, and then replug the power cord. If the display says "full" when it's not, but everything still works, and you can't reset it, you can ignore it, OR, take it apart and see if there is a physical switch that's activated by the level of the water to determine what the display is reading, and try to fix or adjust it.
Sep 20, 2012 | Kenmore 54701 Dehumidifier
The full light stays on, and now it wont collect moisture how do I reset my dehumidifier so that it will continue to work effeciently??
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 10, 2011 | Soleus CFM-40 Dehumidifier
The bucket full light stays on while it is empty. the humidity control doesn't change. the unit is not going on.
There should be a switch that is activated by a float lever that if tripped will make the bucket full light stay on, and will prevent the unit from going on.
If this light is on when the bucket is empty, maybe try to jiggle the float lever, or investigate why the switch is activated when the bucket is empty.
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
Full light stays on even though the unit is empty.cant turn unit off/on with button while full light is on.
There may be a little rod of lever which is pressed by the float in the bucket when it is full - I suspect that it may be jammed in the "up" or "full" position.
If you can see it and pull it down to its normal position the machine should start again.
Hope this helps, but if not let me know what you find. Cheers, D.
Aug 03, 2008 | Maytag M7DH45B2A Dehumidifier
GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 19, 2008 | Dehumidifiers
Miele S8 Cat and Dog S8380 with Free Hepa Filter Logo
181 people viewed this question
Top Miele Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Miele Dehumidifier Expert? Answer questions, earn points and help others
