Question about Dirt Devil Vacuums
I took it apart to clean and now the hose wont suck/whats wrong?
    Top Expert:
  • Dirt Devil Master
  • 10,875 Answers
You broke it
Posted on Mar 27, 2015
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
Our Dyson sucked something up last week (not sure WHAT) and now the telescoping hose won't ****. Well, it sucks but just BARELY . I took the hose apart and can't see anything, but it makes a weird noise...
Well if the hose is completly clear the blockage is either before that or after that the brush roller should come out to clean the tube as you know also comes out make sure all are clear right up to the collector
Jul 17, 2010 | Dyson DC14 All floors Bagless Upright...
My Dyson turns on and is not sucking. It makes a
I have the dyson dc 27. On the bottom left back side of mine there is a circle, and ball inside of it. I turned it on and pushed the ball and it started working again. Sometimes it doesn't cover the whole and stops sucking air through it.
May 18, 2010 | Dyson DC07i Bagless Upright Vacuum
Bissell ProHeat 8910 wont spray water or solution
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sgb
Mar 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Vacuums but doesn't go into the collector
check to make sure there is no blockage in the hose.
Apr 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
May 21, 2007 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuums Logo
78 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
