Question about Ovens
Top oven (Grill) makes a noise when turned on
  • Ovens Master
  • 3,463 Answers
It will not be the grill that is noisy, but more than likely the top oven cooling fan located under the top cover of oven
Posted on Mar 31, 2015
Top oven will not turn on
Make and Model of the oven in question?
Apr 14, 2017 | Ovens
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Main oven trips electric when switched on top oven works fine also grill . did notice that fan was making a noise
If the fuse or circuit breaker is tripping it is most likely a short circuit in the oven element.
Feb 09, 2011 | Tecnik TKC8082 Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
My oven fan is making noise what should i do?
check to see why it is making noise. look at the fan while it is spinning DO NOT INSERT YOUR HANDS and see if you can see what the fan is hitting and why it would be hitting whatever it is hitting could be the shaft onthe motor is maybe bent or a blade is bent on the fan blade itself or maybe something fell into the fan and that might be makin the noise hope this helps
Jul 17, 2010 | Ovens
Noise
It will be the external cooling fan that is causing the noise.
Probably worn beaqring or broken fan blade.
Normally, the only solution is to replace the fan motor.
It is located at the top of the oven, usually at the rear, but not in every case.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Zanussi Ovens
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
Ovens Logo
104 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
