Question about Electrolux Refrigerators
Have CE error which wont reset after power down. Unit is 6 yrs, model EI23BC55IS1. I was told it's the board, WHAT board? There are 2: User Interface and Main Pwr Ctl. Which is more likely to fail?
Can you also tell me the PN of the bd to replace? thanks.
  • Official Brand Answer
  • 4,342 Answers
Hello Mike, thank you for your post!
I see that you are receiving a "CE" error on your Electrolux refrigerator and you would like to know which board could be bad. This code stands for a communication error within your refrigerator I would suggest performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. I understand that you would like to know which board could cause the problem. In order to pinpoint which board could be faulty you would need to disassemble your refrigerator and test each electrical board to make sure that they are receiving the proper charge. I would suggest consulting with a professional technician for proper diagnosis and repair. This will help you avoid unnecessary part purchases. I hope this is helpful. -Matt
Posted on Apr 02, 2015
4 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: FREZZER IS COLD FRIDGE IS NOT
OK, Sounds like we have a problem with the defrost. Need to unplug and lets remove the rear panel and examine the defrost heater, It has a glass tub around it so it will be easy to see if its burned out. WR51X10101 Defrost Heater if you need to change the defrost heater it would be a good idea to replace the defrost thermostat also. Part number WR50X10054 Defrost thermostat. Let me know if I can be of more help. And please rate my solution, Sea Breeze
email appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
http://appliancepartseast.blogspot.com/
Posted on Aug 12, 2009
SOURCE: Same prblem as person who listed Alarm going off
I ended up buying the parts from Electrolux - cost $384 plus tax. The repair is relatively easy and you can do it yourself. My problem was locating the main power board - who would have thought it would be behind the front kick plate attached to the bottom of the refrigerator.
Posted on Oct 21, 2011
SOURCE: SYCF error on frige. Error was not caused by main
good deal - glad you got working,
sorry to hear about the lowes trouble
Posted on Jan 04, 2015
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
The past 3 nights I've had power failure on my EI23BC55IS1 3 door refrig, disable the alarm and it makes all ok but happens over and over. Thismorning it was not working other than code CE in the door
Hi Rayna! From what you have described it sounds as if your refrigerator is experiencing an internal communication error (CE). For this particular error code, a professional technician would be required to check the wiring connections between the main control board (brains of your appliance) and the user interface board (control touch pad on the front of your appliance). Once these connections have been checked, the technician will know which component(s) will need to be replaced; if any.
Let me know if I can be of any more help.
Thanks, Chris
Dec 18, 2013 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Error message 5y ce
Good Afternoon Cheryl, I am happy to assist you. Could the error code possibly be SY CE? If so, error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the refrigerator. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 30, 2013 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Codes sy ce refrigerator display
Good Afternoon Johnny, thank you for your inquiry! Error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the unit. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 27, 2013 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Ce code on electrolux dryer
Hello - Error code CE typically indicates a communication issue between the user interface and main control board. Try resetting the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and restart unit. If the error code does not clean, contact a professional to move forward accurately for a proper diagnoses.
Jan 15, 2013 | Electrolux Dryers
Error code CE
"CE" error mean you have a communication error at power up. Check wiring between Main Control Board and User Interface Board. Replace User Interface Board. If problem still exist, replace Main Control Board. Good luck
Sep 09, 2012 | Electrolux Refrigerators
Display panel shows CE
CE is a general communication error. If you do not see any other error codes on the unit Check wiring between Main Control Board and User Interface Board. Replace User Interface Board. If problem still exist, replace Main Control Board.
Sep 01, 2012 | Electrolux EW26SS65G Side by Side...
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Refrigerators Logo
217 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
