Question about Soleus Dehumidifier SG-DEH
How to fix scale
Change battery in taylor scale model 5700 digital scale with body index readout
I cant change humidity levels
Hi Ra Ma,
After you have set the desired humidity, the readout will display the actual room humidity. It has a built in hygrometer which will be on the display while it is running.
You change it and it shows the actual levels.
See page 5 on manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Mar 02, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Mar 11, 2013 | Dehumidifiers
What setting should my Maytag be on.............Room Humidity or Room Temperature. I am getting no water in pail. I have Model number..........M7DH45B2A
If you want to remove humidity rather, than maintain what's in the household air at this time, You should lower the humidity setting well below what the LED readout shows. Usually 35 to 40% is the optimal setting.
Hope this helps you. Please let me know. Thanks.
Jun 07, 2011 | Dehumidifiers
I have a 50 series w/ digital humidity level readout. Recently unit reads the room at 30% humidity so it shuts off unless preferred setting is set to continuous. Can the sensors go bad that measure the...
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
May 16, 2011 | Frigidaire FDF50S Dehumidifier
Humidity sensor reads to low and does not kick the machine on. The readout seems to always be at 20% and wont kick on till 35% Is there an adjustment i can make to tuen the unit on?
It probably doesn't need adjusting, It's simply a case that 20%, there's not enough humidity for the sensor to read. But, at 35% there is. I'd say, your dehumidifier is working as it should.
FYI - there is no adjustments to change the factory settings.
Hope this helped you, chu.
May 16, 2011 | Fedders 30-Pint Dehumidifier Dehumidifier
Can you tell me about the "P" readouts?
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
May 02, 2010 | Danby DDR601 Dehumidifier
My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
Sep 14, 2009 | Dehumidifiers
Error code on Digital LG Dehumidifier - CH 1
Change the sensor assembly, Part # 6877A30013M from Appliance Factory Parts in Englewood CO, about $30. Easy to change, plugs into control board, remove old temperature probe by pry T-well open with small screwdriver and then crimping back closed when new sensor is installed, about an hour start to finish, hardest part is getting all the covers off. Mine is back to working like new again!!
Nov 10, 2008 | LG DH404E Dehumidifier
Soleus Dehumidifier SG-DEH Logo
95 people viewed this question
Top Soleus Dehumidifiers Experts
NOEL
NOEL
J.D. Browning
J.D. Browning
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
