Question about Miscellaneous
No electric point can i use 13amp plug? - Miscellaneous
Can I connect my electric gas stove to my normal 230 v house plug
I assume you mean a 13amp plug? You'd need to check the kilowatt rating of the appliance. Also, depending on where you are, what regulations are in place regarding electrical works. In the UK, only part p registered electricians are permitted to carry out any electrical works in domestic kitchens, which includes wiring of appliances other than a 3 pin 13amp plug. Hope this answers your question
Jan 12, 2018 | Kitchen Ranges
Does it need 6mm hard wired cable or can it be used with standard 13amp plug via ring min
hard wired is the normal way ranges are done unless they are gas .then the electric can be lighter gauge
Apr 23, 2016 | Ovens
Awz8812 blows fuse
what 13 amp external fuse are you speaking about? if this is a power line fuse feeding the dryer then its way too small normally you use 2 30 amp fuses or a 30 amp tandem pole breaker to power the receptacle where the dryer plug plugs in
May 05, 2012 | Whirlpool GEW9250 Electric Dryer
Can i use a normal 13amp plug on a dimplex plx1500 panel heater
Probably not the best idea. It may overheat when the heater is running at the high setting. Best to use a 15A rated cord and plug.
Nov 01, 2011 | Dimplex Compact Electric Flame Stove...
CAN I CONNECT A CREDA 2000W PLINTH HEATER USEING A FUSED PLUG?CREDA 2000W PLINTH FAN HEATER
Yes ,you can and fuse at 13amp.
Although the correct way would be to terminate the plinth heater in a switched fused spur or an unswitched fused spur fused at 13 amp
This can either replace a single or double socket or it can be taken of the socket by using 2.5mm2 twin and earth cable.
All parts availiable from hardware store or electrical retailer
Oct 06, 2009 | Creda C362E Electric Kitchen Range
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Plug amp
Yes it should be safe to use a 13 amp fuse.
The convention with fuses is up to 720 watts a 3 amp fuse should be used and above 720 watts a 13 amp fuse should be used.
To be precise you need to know the exact wattage of the kettle.
Sometimes maufacturers will fit 5 amp fuses but these are only good for a power rating of 1200 watts maximum (at 240 volts).
So as your kettle is rated at more than 1200 watts it needs a 13 amp fuse.
Hope this is a FixYa.
Oct 20, 2008 | Breville SK85XL Nova Cordless Electric...
Miscellaneous Logo
27 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
