Question about Building Materials
This is a basic question. We have old fashioned tilt up garage doors. They are wood and use springs on each side to open the doors and keep them open. I want to adjust the springs because: 1 one door will not stay open and 2 one door is very hard to open. The question is: How can I adjust the springs?
  • 2,223 Answers
You move them up or down on the chain link on the bottom or on the holes on the garage door frame where they attach at the top. proper adjustment has the door open about half way with free travel on the opener. you also can change the size/length of the spring to adjust tension one way or the other. generally the best adjustment is from the bottom. an obviously, it is easiest to move the springs when the door is fully open. block it fully open with a long 2x4 or something as you do this, otherwise the door will fall good luck
Posted on Mar 28, 2015
My garage door will not open. I pulled on the emergency rope to see if that would help but it did not.
Your torsion spring is probably broken. After you pull on the emergency rope, press the remote, that should move the chain and emergency lock out of the way, then you and 1 or 2 other people may be able to lift the door up if you really need to get the vehicle out. It depends if it is a single or double door or wood or metal, how heavy it will be. This can be dangerous and it could fall down on you. Check your torsion spring above the top of the door when closed, if there are two pieces then it is broken (on a single door.) A double door will have two springs, one on each side. One may be broken. You will need to get all the springs replaced, it counterbalances the door. If you have a garage door with arms on it, then the compression/extension spring is probably broken. If you are mechanically inclined, you can replace them, it is dangerous, be sure to watch a UTUBE video on it.
Dec 21, 2014 | Building Materials
Can I fix a broken garage door extension spring myself ?
Yes you can!
Raise the door all the way. place clamps or vise grips on the frame to keep it safely up.
Very carefully, remove the unbroken spring and get a pair of new ones from the nearest overhead door company.
Install the new springs and then and only then remove the clamps.
Jul 13, 2014 | Building Materials
Garage door opener
With the door down ensure the wire rope on each side are exactly the same length.
Apr 30, 2012 | Craftsman 34 Hp Garage Door Opener Chain...
How do I adjust for a lighter garage door?
Sounds like you now have a very dangerous situation. The door is now lighter but it also less rigid, causing it to bind in the rails and deform them. The flexing of the door must be addressed. That said, the adjustment you need for a lighter door is found in the large torsion springs above the door . But these springs are VERY POWERFUL and can be LETHAL! If you had to ask this question, you are not qualified to attempt this adjustment, and to do so will risk SERIOUS INJURY or DEATH. PLEASE call a qualified garage door service company!
Feb 15, 2010 | liftmaster Chamberlain Garage Door Opener...
Craftsman 1/2hp garage door opener does not go down to floor
I'm no expert, but on a previous door opener I had (don't know the brand), the side adjusting screw basically adjusted a limit switch, which was located inside the plastic housing (where the motor is). I was able to remove the housing, figure out which limit switch was actually being contacted "too soon" on the way down and adjusted it while watching it.
Just a suggestion, you might take a look.
just keep your hands out of the way of the chain and sprocket if you do take the housing off. .
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Gaarage Door
Have you looked on both sides of the door at the bottom there should be cables. If they are not tight you probably have a damaged spring. Look up between the door and where the roller mounts are, there should be a tightly wound spring. This is what keeps the door up, if tension is lost then it will come back down. If it is broken it needs professional attention.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener
The screws that attach to the garage door from the arm pulled out of the garage door and left holes in the panel. I tried to anchor the screws but they keep pulling ou..what do I have to do to secure the screws in?
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster rack keeps stripping
what do you mean by rack. do you mean fears. do you have right sprigs on door, is door balanced. lift half way and let go (Disconnected by arm). It should stay put or go slowly up or down. If not, springs are bad, I put a 1/4 hp on 18' wood door. lasted 27 years so far. H/p not the problem.
Mar 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
95 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
