Question about Pool & Spa
Where can I get diagrams and schematics for my unit? I need to find and prime my water pump
  • 1,631 Answers
We here on this forum, cannot assist you very well, without knowing exactly what we are helping you with? So, what is the make and model of your equipment, and what is it?
please be specific, because most of us in this tough economical climate, really don't have extra dollars to buy batteries for our crystal balls.
Posted on Mar 30, 2015
How do I prime my flotec 4022 pump
A number of Flotec pump manuals are available here: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx . The site lists a FP4022-10 pump with the direct link to the manual here: http://www.flotecpump.com/resources/images/514.pdf .
For this type of pump, there should be a priming plug or priming tee. Remove the plug (or tee) and pour water into the pump. Keep adding water until the pump and all of the piping to the well is full of water. If a priming plug or tee was also added on the suction side of the pump, open that section and fill all of the piping on the suction side with water. Replace the plugs/tees then open a faucet in the house. Start the pump. After 2-3 minutes, turn off the pump if no water has come through the unit. Add more water through the priming plug or tee (or multiple plugs and tees). Then repeat closing the priming ports and start the pump after opening a faucet. Once the pump is actually pumping water, turn off the open faucet. Wait for the pump to shut off once it reaches full pressure. Open one or two faucets to check that the pump is properly sensing the pressure changes and maintaining system water pressure.
If the unit didn't pull water from the well, check the piping for air leaks. See the full trouble-shooting guide in the manual. Page 9 has the priming information and page 10 has the trouble-shooting guide.
I hope this helps.
Aug 27, 2016 | Flotec Plumbing
My unit says prime and no outflow.
"Prime" usually indicates the pump is sucking air. Sometimes the valve in the bottom of the water reservoir gets stiff or gunked up; if you turn off the B60, remove the water container and drip some water into the water intake until it's full, turn the unit back on, replace the water reservoir and that little amount of extra water should be enough to allow the pump to work properly.
Apr 24, 2016 | Keurig B60 Coffee Maker
Pump will not prime.
Pump self primes after the housing is initially filled with water. Failure to do this will reslut in the unit not drawing up the water and could potentionaly damage the unit.
Aug 25, 2011 | Flotec Fp4332 1 Hp Convertible Jet Pump ()
Initially when the unit said need to prime, no water would flow out of the steam unit. After pulling the pump out and cleaning it, not sure what was blocking water the steam unit now has water pressure,...
I fixed the same issue by pushing in the water knob "in" towards the machine. Machine than primes normally as the water flow is restored and it resets itself.
Dec 13, 2010 | Starbucks Saeco Italia Digital Barista...
Hubby installed new pump and it shortcycled for awhile then, no psi... not even sure about the condition of the pressure tank ... when water does come it works for a short time and then trickles and stops...
Did he install a self-priming pump, sometimes the will not prime or this one is stopped up from dirt. also is it submersed in the water or above water level. if it is submersed and is not meant to be, it's probably toast and you need to replace it with a submersible type pump that is also self priming. To find the schematic for your system go to your manufacturer, I'm now assuming that this is a recreation type situation, trailer, motorhome. There at the dealer the parta department should be able to help you. Hope I helped.
Oct 06, 2010 | Flotec Corrosion Resistant Shallow Well...
My B70 loses prime when drawing water from the reservoir. After a few seconds of the pump running and no water being pumped, the unit will automatically shut off. The reservoir is fully seated. Does...
The problem might be common however, Keurig does not have any repair centers around the country, nor do they have schematic drawing available :(. In order to get your problem taken care of you have to call Keurig directly 1.866.901.BREW
Sep 15, 2010 | Keurig Platinum B70 Coffee Maker
10000 gal pump
as with any pool pump they have to prime themselves,, close up the unit as it was before,, and turn it on,, remember that water is also the cooling agent for these pumps, check to see that its pumping water as before,, ( yours may even have a place to prime it,, Look for an easy access prime hole in the pump unit itself )
Aug 02, 2010 | Intex 1000 Gallon Easy Set Swimming Pool...
Priming problem
Make sure you try to prime right when the machine is turned on, so that there is no boiler pressure making it more difficult to prime.
Johnny C
Sales & Service
www.CeriniCoffee.com
Oct 21, 2007 | Starbucks Saeco Italia Digital Barista...
Pool & Spa Logo
42 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
