Question about Garden
Looking for grass box and chute - Garden
  • Garden Master
  • 2,478 Answers
Make and model
Posted on Mar 27, 2015
Troy Bilt self propelled walk behind...grass goes everywhere!!
Mine works,great,take bag off and it will mulch it and look like it's being bagged up.Is your grass knee high?Do you have it low enough?Here's your manual,read the part on grass catcher and see if your doing something wrong,make sure grass door is open.Check your blade to make sure they didn't put it on upside down.The cut part should be facing out. http://pdf.lowes.com/operatingguides/043033566280_oper.pdf
Jul 21, 2017 | Troy Garden
The grass collection tube keeps getting plugged up and will not pass into collection bins.
Tom, Grass chutes get rough on the inner walls of chute over time, try to wipe/scrub inner chute the best you can. After thoroughly clean and dry, try and wax and buff inner chute with car wax the best you can, so chute will be a little more slippery and expel grass better. You may have to do this once or twice a season. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 16, 2016 | Garden
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 | Worx Garden
Mower is not picking up grass plugging in chute
Did you just replace the blade ? If so, it might be on upside down, which would produce no upward suction.I assume you're not mowing right after rain. If there's a buildup of old grass gunk around the chute, scrape it off. Remember always to pull the plug wire off before reaching under the mower!
Mar 07, 2015 | Garden
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
Aug 31, 2014 | Garden
Grass collector not filling
HMM .. if the grass is not going into the collector, I would look under the deck and see if there is something blocking the chute to the bag.
Please vote !!
May 12, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Apr 22, 2009 | Garden
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Tractor mower failing to collect grass
ok i need to know what kind of collection sys. you have.if there is an electric blower type system it may be that the blower isn't working. if the system works by the blade blowing the grass up the chute then you may want to check the blades to see if the up turned tabs on the back of the blades are still there and not broken off. also if your mowing too fast the chute gets clogged and the grass just balls up onder the deck ubtil rolled out.if a blower type set up check to see if there is a fuse to the blower motor.
Apr 22, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
