Many laptop computers come equipped with a small web camera assembly mounted above the LCD screen. Like any other camera, these webcams use a lens to take pictures. Over time, it is possible for this lens to become dirty, especially if you have touched it a few times. You can quickly clean the lens and get the unit back to taking crisp pictures.
1.Take a microfiber cloth and gently press it to the lens of your laptop's web camera.
2.Gently rub the lens of the web camera with the microfiber cloth. Be sure that you cover the entire surface of the web camera's lens.
3.Open your web camera program when you are finished and take a picture to test the quality of the webcam. If it is still blurry, close the program and repeat steps 1 and 2 until the web camera is no longer blurry.
Rose,
Your web cam is blurry because you have not focussed it. Please put it on and when you see yourself in it, then rotate the black ring around the lens both clock and anti clockwise till you see yourself clear.
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
There is a focus ring around the lens of the WEB cam turn this ring until your image becomes clear, just like a camera focus knob.
Click on the WEB cam software, you will be able to go into an options or configuration, click on video setting, you should see an image of yourself, adjust the focus until the image is clear.
