Question about Samsung PN64F8500AF 64" 3D 1080p Plasma TV - 16:9 - HDTV 1080p - 600 Hz ATSC - 1920 x 1080 - Dolby Digital Plus, Dolby Pulse, Surround Sound, DTS - 4 x HDMI - USB - Ethernet - Wi-Fi
Samsung plasma tv does not power on consistantly
My tv for the most part will not power on the first time. It may the second time but sometimes it takes numberous attempts to get it to power on. I changed the power supply board and it did not correct the issue.
  • 304 Answers
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Posted on Jul 17, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 2427 Answers
SOURCE: Whats involved in installing a
hmmmm its easy really..
  • unscrew rear cover
  • cables from power board to other components
  • unscrew and remove power board
  • put in new board and screw down
  • re connect cables
  • screw back on the rear panel
  • plug in
  • turn on
  • watch!!
Posted on Sep 14, 2010
Testimonial: "Thanks for the easy fix!"
SOURCE: will a power supply for a 50" plasma TV work with a 42" plasma TV?
sir it will work with your TV..
Posted on Mar 30, 2012
  • 127 Answers
SOURCE: Samsung TV Model LA40A650A1M back light intermittently strobeing
You can't see if a cap is good or bad jus looking at them they have to be measured>They loose their capacitance because they dry overtime.
I do sugest that you replace you power supply module or replace all caps.Possibily you may have a broken line in the PCB
Posted on Nov 01, 2012
Why does upper half of screen go dark?
http://www.shopjimmy.com/samsung-bn96-03365a-g-buffer-board.htm Watch the video. Also be advised that plasma sets are getting very hard to find parts for.
Feb 01, 2016 | Samsung HP-S5053 50 In. Plasma HDTV
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
I have a 50 inch samsung plasma. It is getting lines all the way across the screen. I'm up to 47 lines is there anything I can do to fix it?
Several things can cause problem with plasma TV's. You may be getting electrical noise from an appliance or lighting such as halogen or florescent, dimmers, bad electrical connections and outlets. Also, bad cables can cause problems too; have you tried switching those out? Appliances like vacuums, fans, regrigerators, anything with a motor can cause lines and noise on TV's. Have you tried connecting the TV to a noise suppressing, surge protection power strip? Do the lines come and go, or are they consistently in the same place all of the time? When did you buy the TV and is it still under warranty or an extended warranty? Do you have problems with any other TV's in the house? Look at each of these solutions, try them one by one to narrow down the potential source of the problem. If you've tried everything I've mentioned, it may be a bad TV. It does happen, but not often. And as a former Samsung dealer/installer, I know Samsung products have really good track record. In fact, every TV and smart phone phone in my home is Samsung. Hope this helps.
Feb 07, 2015 | PN50C675 Samsung Factory Refurbished...
Samsung plasma tv model ps42a457p1d when you turn power on power indicater light comes on for a few seconds then dissapears tv dead
My Samsung 42inch plasma ps42a457p1d won't come on at all I've switched it off & on & changed the fuse the light came on for a few seconds then went off again
Feb 04, 2013 | Televison & Video
Samsung plasma 50in PS50B550 clicking noise
The clicking could be a loose connecction of the power plug or frrom the main power unit of your TV. Remove your plug and see the ends for burn outs, if so clean and use a different outlet. If not open the set after disconnection and check your main power supply unit for loose connection particularily in the surge protector, the main capacitor, the main drive, diodes or connectors. Wait to hear the sound and use a long insulated rod as a probe to confirm the origin of the sound. Solder or replace the damaged item. Hope this helps . Good day
Jul 22, 2010 | Samsung Televison & Video
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
Samsung HP-R5052 Plasma TV
It related with Power Board(50%) or Y-Main(50%).
But, if you use the power bar with surge protacton, need to check
the power bar's lamp when the TV is turning on & off.
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung HP-R5072 50' Plasma. Has sound, but no picture.
the Y-main board is going out, or the Y-scan buffer, but probably the Y-main
Dec 09, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
42 inch plasma
TURN OFF THE MAINS AND THEN SWITCH IT BACK ON
Jun 06, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung PN64F8500AF 64" 3D 1080p Plasma TV - 16:9 - HDTV 1080p - 600 Hz ATSC - 1920 x 1080 - Dolby Digital Plus, Dolby Pulse, Surround Sound, DTS - 4 x HDMI - USB - Ethernet - Wi-Fi Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
