Question about GE Washing Machines
How do i hook up how do i hook up power source to ge washer
  • GE Master
  • 473 Answers
It should just plug in. should be a 120 volt power cord attached to the machine back. If its missing you need a power cord.
Posted on Mar 31, 2015
Old GE 27GT615 TV won't power on
Could be an open internal fuse or power supply failure
Dec 19, 2017 | GE Televison & Video
My front load GE washer would not drain . balance looks fine. pulling the power source and replugging did not help ... - posted in Washing Machines
try looking for filter trap assy see if anything stuck in it ... when operating washer is the door lock mechanism locking usualy make a buzzing click then a buzzing click .. these doorlock have been problematic .... but check filter sump trap first bottom right corner of washer
Jan 24, 2011 | Whirlpool Washing Machines
My front load GE washer would not drain . balance looks fine. pulling the power source and replugging did not help WCVH6800J1WW Serial IS205695T -
if this washer has a control board on top of motor try opening the lid six times within 6 seconds... then start washer .... if it does have board ontop of motor look at board is green indicator lit up if not replace fuse link white wire with red line threw it from motor has a one time fuse link in wire replace fuse link or jump across to test
Jan 24, 2011 | GE WJSR2070B Top Load Washer
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
When I first started using my washer when I hooked up the water it would fill the hose and then stop until I started the machine. Now when I hook up the washer to the faucet water starts to fill the machine before I close the lid and before I start the washing process....? The last time I used the machine it didnt drain and I had a flood, is there a problem with it now???
Jan 09, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Washing maohine doesn't take water '
If you have established that the water is reaching the washer, then either there is ni power to the valves, or the valves are faulty.
Hope this helps.
Jan 27, 2010 | GE Washing Machines
How to hook up the water to the dish washer
Your dishwasher has a water line in and a waste water tube on the back of it. You need a source water line where the DW is at and you simply connect it. The drain hose needs to hook up to a waste water trap on a sink or somewhere. Power it up and that should be all there is to it. I suggest that you hook it up with a couple of extra feet of hose though incase you need to pull it out for service or something. FYI..
Thanks!
mrstan
Aug 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Washer wont agitate or spin
if it is the motor try this link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230151
Dec 04, 2008 | GE WJSR2070B Top Load Washer
Washer set up to go but................
First check to see if there is power in your wall socket by plugging in another appliance there. Then check the fuse in your washer plug, check wires too in plug..................
May 03, 2008 | GE WSXH208A Front Load Washer
Audio
Source is ? ...........Cable box ? = check red and white audio
output hook-up to red and white input hook-up on back of tv...
Check audio selections in menu = select stereo, not SAP
Check speaker wiring to one that's out..........
.....................................................................................T.
Dec 23, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Washing Machines Logo
55 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
