Question about Apple iPhone 5c
Screen is stuck fully expanded on startup screen
Screen will move if i touch the left or right side or the top or bottom edges
  • 59 Answers
Maybe you have turned on the Zoom settings from the Accessibility menu. To zoom out, Triple tap the screen with three fingers until the screen zooms out. To disable Zoom, go to Settings > General > Accessibility, look for Zoom then click to disable.
Tips for Zoom:
- To zoom in or out, triple tap the screen.
- To adjust the magnification of the screen, press and hold with three fingers, then scroll up and down to change.
- To navigate the screen, swipe using three fingers to left, right, up or down.
Hope it helps!
Cheers!
-Josh
screen is stuck fully expanded on startup screen - /uploads/images/screen-stuck-fully-expanded-startup-35310085-5-1.jpg
Posted on Apr 06, 2015
  • joshd Apr 07, 2015
    Corrections: Instead of triple-tap, double-tap the screen with three fingers to zoom in or out, also for for adjusting the magnification of the screen double-tap and hold with three fingers then swipe up or down.
2 Suggested Answers
  • 58 Answers
SOURCE: iPhone bottom edge only allows slide functions.
(For restore issues) When hard resetting the iphone unit, sometimes the 2 button reset will not work to force the restore mode. In this situation you should hold the 2 buttons until the display turns off. Then hold the HOME button and while holding it in, plug in the USB cable (powered- ie: plugged into AC adapter or computer USB port). This will power on the phone and bring up restore mode in itunes. iTunes will produce a message which says: "iTunes has detected an iphone in restore mode" -your friendly neighborhood MacGenius from the Apple Store
Posted on Dec 12, 2009
How do i reduce the size of a monitor
Hold down the ALT key.
Touch the SPACE bar.
Touch the S ("size" key).
Touch LEFT-ARROW key.
Repeatedly press the RIGHT-ARROW key to move the left edge of the window to the right.
Touch the UP-ARROW key.
Repeatedly press the DOWN-ARROW key to move the top edge of the window towards the bottom.
Touch ENTER to "commit" the changes.
May 09, 2015 | Dell E173FP 17" LCD Monitor
How do you open up a Sony rm-gd008 remote for cleaning?
  1. Maybe worth a shot, carefully thou
  2. Remove 2 * screws under battery cover
  3. front of remote: slide down the bottom cover (where rec, pause, etc option is)
  4. push both egdes of the slide area outwards, to totally remove this slide cover
  5. further more, now push both the above slide edges even more .. till bottom of (front face) cover loosens up. Whilst lifting this only a little at a time ...
  6. Gently remove /loosens only lower ends (only at this stage) of the 2 silver edge stripes... by .. lifting up (away from face of remote) ..whilst .. moving them outwards. ** i.e up, then outwards) Do not remove top edge of silver tip yet
  7. start separating left n right egdes with sharp flat point from under silver side strip, " digging" downwards towards bottom of remote
  8. At this point, the top edge of remote may be separated, but not necessary.. if you can pull insides out from bottom, PREFFERED OR .. can be done by:
  9. using flat edge - loosen/pry 1cm from corner on top tip of edge left n right digging downwards n outwards towards bottom of remote .. enough gap to use a little pressure if you must
  10. then if feasible, separate remote face .. also 1cm from right n left corner alongst each side from top corner
  11. .. now can remove silver side strip completey.
  12. Hope this helps, cheers
Dec 04, 2012 | Televison & Video
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 20, 2011 | Watches
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
I have the quilters 150x150 hoop and I need an update to use it, the button on my embroidery machine is grey I think it needs to be dark blue
Dark grey, actually, but you don't need the upgrade. Set the hoop size at the machine for the 150 x 240 hoop and the 150 x 150 hoop will work. Just be sure that the design starts in the centre i.e. don't move it up or down at the machine Embroidery screen. Before you begin sewing, check that the design will fit in the hoop without bumping the sides of the hoop. Use the Check Size button which is on the second screen of the Embroidery Screen (touch More on bottom right of first screen). The Check Size button is the one on the bottom right - the first button to the left of "More". Touch it once, hoop moves to top left of design; touch again hoop moves to bottom left of design; again hoop moves to bottom right; again hoop moves to top right.
Make yourself a note so that when you next take your D1 in for its regular service, get the hoop upgrade done at the same time. You need to have at least version 2.1 of the machine software installed - your tech. can do this for you too. It is a really minor adjustment so should not add much to the service cost. Be sure to take the embroidery unit in too when you go for the service.
Nov 16, 2009 | Husqvarna Designer I
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
MacBook opening screen leaves a one inch black strip on both sides.
use the gray bar on top to move the screen to the upper left hand corner.  Then click and drag the bottom right portion of the screen to the size that you want it be.
Mar 21, 2008 | Apple MacBook PC Notebook
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
Open Questions:
See all Apple iPhone 5c Questions
Apple iPhone 5c Logo
73 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
